Ciao, scusate stavo provando lo sketch già fatto per la lettura di un sensore dht22 su applicazione android. Il mio problema è che mi da un errore di compilazione che non comprendo :
Arduino:1.8.5 (Windows 10), Scheda:"Arduino/Genuino MKR1000"
C:\Users\xxx\Documents\Arduino\libraries\adafruit-DHT-sensor-library-53e6481\DHT.cpp: In member function 'boolean DHT::read()':
C:\Users\xxx\Documents\Arduino\libraries\adafruit-DHT-sensor-library-53e6481\DHT.cpp:109:7: error: 'cli' was not declared in this scope
cli();
C:\Users\xxx\Documents\Arduino\libraries\adafruit-DHT-sensor-library-53e6481\DHT.cpp:139:7: error: 'sei' was not declared in this scope
sei();
Qualcuno saprebbe dirmi dove sbaglio? allego il codice qui sotto:
[code]
#define BLYNK_PRINT SerialUSB
#include <SPI.h>
#include <WiFi101.h>
#include <BlynkSimpleWiFiShield101.h>
#include <DHT.h>
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "YourAuthToken";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "YourNetworkName";
char pass[] = "YourPassword";
#define DHTPIN 2 // What digital pin we're connected to
// Uncomment whatever type you're using!
#define DHTTYPE DHT22 // DHT 22
DHT dht(DHTPIN, DHTTYPE);
BlynkTimer timer;
// This function sends Arduino's up time every second to Virtual Pin (5).
// In the app, Widget's reading frequency should be set to PUSH. This means
// that you define how often to send data to Blynk App.
void sendSensor()
float h = dht.readHumidity();
float t = dht.readTemperature(); // or dht.readTemperature(true) for Fahrenheit
if (isnan(h) || isnan(t)) {
SerialUSB.println("Failed to read from DHT sensor!");
return;
// You can send any value at any time.
// Please don't send more that 10 values per second.
Blynk.virtualWrite(V5, h);
Blynk.virtualWrite(V6, t);
// Debug console
SerialUSB.begin(9600);
Blynk.begin(auth, ssid, pass);
// You can also specify server:
//Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 8442);
//Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8442);
dht.begin();
// Setup a function to be called every second
timer.setInterval(1000L, sendSensor);
Blynk.run();
timer.run();
[/code]
Vi ringrazio molto.
