[code][code]#include <SPI.h> // Used by Blynk
#include <Ethernet.h> // Used by Blynk
#include <BlynkSimpleEthernet.h> // Used by Blynk
#include <Wire.h> // I2c
#include "DHT.h" // Use Arduino 20k pullup resistor 'activated in code'
#define BLYNK_PRINT Serial
char auth[] = "Auth Key";
WidgetLCD lcdA(V0); //Set LCD widget to Advanced Mode - Widget to display project clock
WidgetTerminal terminal(V1);
// DHT Reference Values - CHANGE THESE TO MANAGE YOUR ROOM'S CLIMATE - //
byte hiMaxTemp = 80; // temp that triggers heat removal device(s) on
byte lowMaxTemp = 70; // temp that triggers heat removal device(s) off
byte hiMinTemp = 55; // temp that triggers heater on
byte lowMinTemp = 65; // temp that triggers heater off
byte hiHum = 50; // High humidity value that triggers dehumidifier on
byte lowHum = 40; // Low humidity value that triggers dehumidifier off
float PHprobe = 15; //pH meter connected to digital 15
BLYNK_WRITE(V2) {
PHprobe = param.asFloat(); //
#define lightA 22 //Relay 1/a
#define lightB 23 //Relay 2/b
#define pumpA 24 //Relay 3/c
#define pumpB 25 //Relay 4/d
#define ROpump 26 //Relay 5/e
#define scrubberFan 27 //Relay 6/f
#define heatVentA 28 //Relay 7/g
#define heatVentB 29 //Relay 8/h
#define TURN_ON 0 // TURN_ON and TURN_OFF are defined to account for Active LOW relays
#define TURN_OFF 1 // Used to switch relay states for on/off of 120VAC~ devices
float b;
DHT dhtA(A0, DHT22); // DHT instance named dhtA, (I/O pin, sensor type)
DHT dhtB(A2, DHT22); // DHT instance named dhtB, (I/O pin, sensor type)
BlynkTimer timer; // SimpleTimer instance named timer
//Serial2.begin() // For other baud rates
//Serial3.begin() // For other baud rates
Blynk.begin(auth);
dhtA.begin();
dhtB.begin();
pinMode(A0, INPUT_PULLUP); // DHT22 use internal 20k pullup resistors
pinMode(A2, INPUT_PULLUP);
Wire.begin();
while (Blynk.connect() == false) {}
timer.setInterval(2000L, pHread); // 2 second intervals between timed routiness
timer.setInterval(5001L, climateRoutine); // 5 second intervals between climate routines
void climateRoutine()
byte h1 = dhtA.readHumidity(); // f1 and h1 are fahrenheit and humidity readings
byte f1 = dhtA.readTemperature(true); // from DHT/A
byte h2 = dhtB.readHumidity(); // f2 and h2 are fahrenheit and humidity readings
byte f2 = dhtB.readTemperature(true); // from DHT/B
if (isnan(f1) || isnan(f2) || isnan(h1) || isnan(h2)) {
terminal.println("Failed to read from a DHT sensor");
terminal.flush();
return;
Blynk.virtualWrite(V3, f1); // Set Virtual Pin 0 frequency to PUSH in Blynk app
Blynk.virtualWrite(V4, h1); // Set Virtual Pin 1 frequency to PUSH in Blynk app
Blynk.virtualWrite(V5, f2); // Set Virtual Pin 2 frequency to PUSH in Blynk app
Blynk.virtualWrite(V6, h2); // Set Virtual Pin 3 frequency to PUSH in Blynk app
//-------------------Bloom A Temp Test---------------------------------------//
if (f1 >= hiMaxTemp) //if "f1" is greater than or equal to hiMaxTemp,
digitalWrite(heatVentA, TURN_ON); // TURN_ON heatVentA (fan).
terminal.println("Exhausting the heat from Bloom A"); // Text printed to terminal monitor
else if (f1 <= lowMaxTemp) // or else if "f1" is less than or equal to lowMaxTemp
digitalWrite(heatVentA, TURN_OFF); // TURN_OFF relay E.
//-----------------------Bloom A Humidity Test-------------------------//
if (h1 >= hiHum) //if "h2" is greater than or equal to hiHum,
digitalWrite(scrubberFan, TURN_ON); // TURN_ON heatVentA (fan).
terminal.println("Exhausting the RH from Bloom A"); // Text printed to terminal monitor
else if (h1 <= lowHum) // or else if "h1" is less than or equal to lowHum
digitalWrite(scrubberFan, TURN_OFF);
//-----------------------Bloom B Temp Test-----------------------------//
if (f2 >= hiMaxTemp) //if "f2" is greater than or equal to hiMaxTemp,
digitalWrite(heatVentB, TURN_ON); // TURN_ON heatVentA (fan).
terminal.println("Exhausting the heat from Bloom B"); // Text printed to terminal monitor
else if (f2 <= lowMaxTemp) // or else if "f2" is less than or equal to lowMaxTemp
digitalWrite(heatVentB, TURN_OFF);
//-----------------------Bloom B Humidity Test-------------------------//
if (h2 >= hiHum) //if "h2" is greater than or equal to hiHum,
terminal.println("Exhausting the RH from Bloom B"); // Text printed to terminal monitor
else if (h2 <= lowHum) // or else if "h2" is less than or equal to lowHum
terminal.flush();
void pHread()
int reading[10], total;
int averageValue; //Store the average value of the sensor feedback
// Put the pH electrode into the standard solution whose pH value is 7.00
// change calibrationOffset to the difference between your reading and 7.00
float calibrationOffset = 0.0;
for (int i = 0; i < 10; i++) //Get 10 sample value from the sensor for smooth the value
reading[i] = analogRead(PHprobe); // returns int (0 to 1023)
total = total + reading[i];
averageValue = total / sizeof(reading);
// Convert the analog reading (which goes from 0 - 1023) to a voltage (0 - 5V):
float voltage = averageValue * (5.0 / 1024);
float phValue = 3.5 * voltage + calibrationOffset;
Serial.print(" pH:");
Serial.print(phValue, 2);
Serial.println(" ");
terminal.print(" pH:");
terminal.print(phValue, 2);
terminal.println(" ");
terminal.flush();
Blynk.run();
timer.run();
That is one massive amount of code for someone who doesn't know how to code.
So what does it do, and what should it do?
Have you been able to get data from the DHT22s by simply reading them and dumping it to the Serial console? (I'm sure there's a piece of example code with the libraries).
Same for the other parts. Anything working on its own?
unsigned long Timer1 = 5000; //Timer for relais 1
pinMode(1, OUTPUT); //relais 1 on pin 1
int sensor1;
if(millis() > Timer1)
if(digitalRead(1)) //if Pin 1 is HIGH
digitalWrite(1, 0);
else //If Pin 1 Low
digitalWrite(1,1)
sensor1 = analogRead(5) //read sensor from Analg pin 5
Timer1 = Timer1 + 5000; //Do this every 5 seconds
It activates/deactivates the first relais every 5 seconds and reads a sensor on Pin5 . Change 5000 to 300 000 for 5 minutes etc... For more relais you need to have
