I have two stepper motors that I control by Blynk and buttons. One motor "small_stepperB" works ok. The small_stepperF get interfered by Blyck code.
Running with the code below two leds is lit (and stays on) on the control board ULN2003 from power up and with no commands sent. The motor jerks around when command is sent to move.
I have removed all blynk code, the leds are off and the motor moves as it should.
The leds are lit when connecting pin 11. Tried other free pins but lit anyhow.
Any ideas why this happens and what to do?
Regards,
Mats
#include <SPI.h>
#include <Stepper.h>
#include <Ethernet.h>
#include <BlynkSimpleEthernet.h>
int pos;
int Steps2Take;
char auth[] = "xxxxxxxxxxxxxxxxxxxxxxxxx";
// Stepper
#define STEPS_PER_MOTOR_REVOLUTION 32
#define STEPS_PER_OUTPUT_REVOLUTION 32 * 64
Stepper small_stepperF(STEPS_PER_MOTOR_REVOLUTION, 7, 9, 8, 11);
Stepper small_stepperB(STEPS_PER_MOTOR_REVOLUTION, 2, 5, 3, 6);
// Blynk
#define BLYNK_PRINT Serial
// Ethernet
#define W5100_CS 10
BLYNK_WRITE(V1)
{int stepp1 = param.asInt(); pos = pos + stepp1; Steps2Take = stepp1; small_stepperF.step(Steps2Take); Steps2Take = 0; digitalWrite(7,LOW); digitalWrite(8,LOW); digitalWrite(9,LOW); digitalWrite(11,LOW); }
BLYNK_WRITE(V0)
{int stepp5 = param.asInt(); pos = pos + stepp5; Steps2Take = stepp5; small_stepperF.step(Steps2Take); Steps2Take = 0; digitalWrite(7,LOW); digitalWrite(8,LOW); digitalWrite(9,LOW); digitalWrite(11,LOW); }
BLYNK_WRITE(V3)
{int stepp10 = param.asInt(); pos = pos + stepp10; Steps2Take = stepp10; small_stepperF.step(Steps2Take); Steps2Take = 0; digitalWrite(7,LOW); digitalWrite(8,LOW); digitalWrite(9,LOW); digitalWrite(11,LOW); }
BLYNK_WRITE(V10) // Bathinov
{if (param.asInt() == 1) { small_stepperB.step(1024); digitalWrite(2,LOW); digitalWrite(3,LOW); digitalWrite(5,LOW); digitalWrite(6,LOW);}}
BlynkTimer timer;
// Debug console
pinMode(0, INPUT); // Button Focuser -
pinMode(1, INPUT); // Button Bathinov
pinMode(12, INPUT); // Button Focuser +
pinMode(2, OUTPUT); // Stepper B
pinMode(3, OUTPUT); // Stepper B
pinMode(5, OUTPUT); // Stepper B
pinMode(6, OUTPUT); // Stepper B
pinMode(7, OUTPUT); // Stepper F
pinMode(8, OUTPUT); // Stepper F
pinMode(9, OUTPUT); // Stepper B
pinMode(11, OUTPUT); // Stepper B
small_stepperB.setSpeed(500);
small_stepperF.setSpeed(100);
Blynk.begin(auth);
timer.setInterval(1007L, updateblynk);
timer.setInterval(200L, read_button_bath);
timer.setInterval(200L, read_button_focusplus);
timer.setInterval(200L, read_button_focusminus);
void read_button_bath() {
if (digitalRead(1) == LOW) {
delay(150);
while (digitalRead(1) == LOW);
void read_button_focusplus() {
if (digitalRead(12) == LOW) {
delay(150);
while (digitalRead(12) == LOW);
int stepp10 = 100; pos = pos + stepp10; Steps2Take = stepp10; small_stepperF.step(Steps2Take); Steps2Take = 0; digitalWrite(7,LOW); digitalWrite(8,LOW); digitalWrite(9,LOW); digitalWrite(11,LOW);}
void read_button_focusminus() {
if (digitalRead(0) == LOW) {
delay(150);
while (digitalRead(0) == LOW);
int stepp10 = -100; pos = pos + stepp10; Steps2Take = stepp10; small_stepperF.step(Steps2Take); Steps2Take = 0; digitalWrite(7,LOW); digitalWrite(8,LOW); digitalWrite(9,LOW); digitalWrite(11,LOW);}
void updateblynk() {
Blynk.virtualWrite(2, pos);
Blynk.run();
timer.run();
