Blynk+stepper motor+HMC5883 error
Need help. I have a problems with controll of stepper motor with blynk. I use HMC5883 i2c and easy driver for control stepper. But i have trouble with 1 direction. I think the problems is in ''void loop''. Conflict in my code. No error but my motor won't work when i add HMC5883 for direction of my tv antenna. Please Help me.
-esp d1 mini+easydrivers+HMC5883+Blynk
#include <Stepper.h>
#include <ESP8266WiFi.h>
#include <BlynkSimpleEsp8266.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_HMC5883_U.h>
Stepper myStepper(200, 16, 14);
#include <Wire.h>
char auth[] ="xxxx";
char ssid[] = "xxx";
char pass[] = "xxx";
int xVal=512;
Adafruit_HMC5883_Unified mag = Adafruit_HMC5883_Unified(12345);
Blynk.begin(auth, ssid, pass);
myStepper.setSpeed(2500);
if(!mag.begin())
/* There was a problem detecting the HMC5883 ... check your connections */
Serial.println("Ooops, no HMC5883 detected ... Check your wiring!");
while(1);
Blynk.run();
//HMC5883
sensors_event_t event;
mag.getEvent(&event);
float heading = atan2(event.magnetic.y, event.magnetic.x);
float declinationAngle = 0.23;
heading += declinationAngle;
// Correct for when signs are reversed.
if(heading < 0)
heading += 2PI;
// Check for wrap due to addition of declination.
if(heading > 2
PI)
heading -= 2PI;
// Convert radians to degrees for readability.
float headingDegrees = heading * 180/M_PI;
Blynk.virtualWrite(4, headingDegrees);
delay(100);
//Stepper joystick
if( (xVal < 500) ){
myStepper.step(1);
delayMicroseconds(150);
}else if( xVal > 550){
myStepper.step(-1);
BLYNK_WRITE(V1)
xVal = param[0].asInt();
