I am receiving an error for my Node MCU. It seems to not like how my code is presented. I am quite new at this, so if anyone knows how to set up Blynk Widgetmap, that would be great. Here is my code:
#define BLYNK_PRINT Serial
#include <SoftwareSerial.h>
#include <ESP8266WiFi.h>
#include <TinyGPS.h>
#include <BlynkSimpleEsp8266.h>
#define D0 16
#define D1 5
#define D2 4
#define D3 0
#define D4 2
#define D5 14
#define D6 12
#define D7 13
#define D8 15
#define D9 3
#define D10 1
int buttonpin = (V2);
TinyGPS gps;
SoftwareSerial ss(D4, D3);
char auth[] = "4df1b2a07afb401a952f7da238393faf";
char ssid[] = "IOT";
char pass[] = "123456789123459876";
static void smartdelay(unsigned long ms);
static void print_float(float val, float invalid, int len, int prec);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_date(TinyGPS &gps);
static void print_str(const char *str, int len);
WidgetMap myMap(V1);
Serial.print("Start Mode");
WiFi.mode(WIFI_STA);
WiFi.disconnect();
Blynk.begin(auth, ssid, pass);
Serial.println("Blynk Connected");
Serial.print("Testing TinyGPS library v. "); Serial.println(TinyGPS::library_version());
Serial.println("by Mikal Hart");
Serial.println("Sats HDOP Latitude Longitude Fix Date Time Date Alt Course Speed Card Distance Course Card Chars Sentences Checksum");
Serial.println(" (deg) (deg) Age Age (m) --- from GPS ---- ---- to London ---- RX RX Fail");
Serial.println("-------------------------------------------------------------------------------------------------------------------------------------");
ss.begin(115200);
myMap.clear();
int index = 1;
Blynk.run();
float flat, flon;
unsigned long age, date, time, chars = 0;
unsigned short sentences = 0, failed = 0;
static const double LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
print_int(gps.satellites(), TinyGPS::GPS_INVALID_SATELLITES, 5);
print_int(gps.hdop(), TinyGPS::GPS_INVALID_HDOP, 5);
gps.f_get_position(&flat, &flon, &age);
print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 10, 6);
print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 11, 6);
print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
print_date(gps);
print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 7, 2);
print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2);
print_str(gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(gps.f_course()), 6);
print_int(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0xFFFFFFFF : (unsigned long)TinyGPS::distance_between(flat, flon, LONDON_LAT, LONDON_LON) / 1000, 0xFFFFFFFF, 9);
print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? TinyGPS::GPS_INVALID_F_ANGLE : TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
print_str(flat == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON)), 6);
gps.stats(&chars, &sentences, &failed);
print_int(chars, 0xFFFFFFFF, 6);
print_int(sentences, 0xFFFFFFFF, 10);
print_int(failed, 0xFFFFFFFF, 9);
smartdelay(1000);
if (WIFI_STA==0xFFFFFFFF)
Serial.print("Wifi not connected");
if (V2, HIGH)
myMap.location(index, flat, flon, "value");
unsigned long start = millis();
do
while (ss.available())
gps.encode(ss.read());
} while (millis() - start < ms);
if (val == invalid)
while (len-- > 1)
Serial.print('*');
Serial.print(' ');
Serial.print(val, prec);
int vi = abs((int)val);
int flen = prec + (val < 0.0 ? 2 : 1); // . and -
flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
for (int i=flen; i<len; ++i)
Serial.print(' ');
smartdelay(0);
char sz[32];
if (val == invalid)
strcpy(sz, "*******");
sprintf(sz, "%ld", val);
sz[len] = 0;
for (int i=strlen(sz); i<len; ++i)
sz = ' ';
- if (len > 0)*
- sz[len-1] = ' ';*
- Serial.print(sz);*
- smartdelay(0);*
{ - int year;*
- byte month, day, hour, minute, second, hundredths;*
- unsigned long age;*
- gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);*
- if (age == TinyGPS::GPS_INVALID_AGE)*
_ Serial.print("********** ******** ");_ - else*
- char sz[32];*
- sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d ",*
- month, day, year, hour, minute, second);*
- print_int(age, TinyGPS::GPS_INVALID_AGE, 5);*
- smartdelay(0);*
{ - int slen = strlen(str);*
- for (int i=0; i<len; ++i)*
_ Serial.print(i<slen ? str : ' ');_
* smartdelay(0);*
[code][/code]
