Blynk_WiFiManager
How To Install Using Arduino Library Manager
To help you to eliminate hardcoding your Wifi and Blynk credentials for ESP8266 and ESP32 (with / without SSL), and updating/reflashing every time when you need to change them.
With version v1.0.7 or later, you now can configure:
1. Multiple WiFi Credentials (SSID, Password) and system will autoconnect to the best and available WiFi SSID.
2. Multiple Blynk Credentials (Server, Token) and system will autoconnect to the available Blynk Servers.
With version v1.0.5 or later, you now can configure:
  1. Config Portal Static IP address, Name and Password.
  2. Static IP address, Gateway, Subnet Mask and 2 DNS Servers IP addresses.
Sample Code
#define BLYNK_PRINT Serial
// Not use #define USE_SPIFFS  => using EEPROM for configuration data in WiFiManager
// #define USE_SPIFFS    false => using EEPROM for configuration data in WiFiManager
// #define USE_SPIFFS    true  => using SPIFFS for configuration data in WiFiManager
// Be sure to define USE_SPIFFS before #include <BlynkSimpleEsp8266_WM.h>
//#define USE_SPIFFS                  true
#if (!USE_SPIFFS)
  // EEPROM_SIZE must be <= 4096 and >= CONFIG_DATA_SIZE (currently 172 bytes)
  #define EEPROM_SIZE    (4 * 1024)
  // EEPROM_START + CONFIG_DATA_SIZE must be <= EEPROM_SIZE
  #define EEPROM_START   1024
#endif
// Force some params in Blynk, only valid for library version 1.0.1 and later
#define TIMEOUT_RECONNECT_WIFI                    10000L
#define RESET_IF_CONFIG_TIMEOUT                   true
#define CONFIG_TIMEOUT_RETRYTIMES_BEFORE_RESET    5
// Those above #define's must be placed before #include <BlynkSimpleEsp8266_WM.h>
#define USE_SSL   false
#if USE_SSL
  #include <BlynkSimpleEsp8266_SSL_WM.h>
#else
#endif
    // From v1.0.5
    // Set config portal SSID and Password
    Blynk.setConfigPortal("TestPortal", "TestPortalPass");
    // Set config portal IP address
    Blynk.setConfigPortalIP(IPAddress(192, 168, 220, 1));
    // From v1.0.5, select either one of these to set static IP + DNS
    Blynk.setSTAStaticIPConfig(IPAddress(192, 168, 2, 230), IPAddress(192, 168, 2, 1), IPAddress(255, 255, 255, 0));
    //Blynk.setSTAStaticIPConfig(IPAddress(192, 168, 2, 220), IPAddress(192, 168, 2, 1), IPAddress(255, 255, 255, 0),
    //                           IPAddress(192, 168, 2, 1), IPAddress(8, 8, 8, 8));
    //                           IPAddress(4, 4, 4, 4), IPAddress(8, 8, 8, 8));
  // Use this to default DHCP hostname to ESP8266-XXXXXX or ESP32-XXXXXX
  //Blynk.begin();
  // Use this to personalize DHCP hostname (RFC952 conformed)
  // 24 chars max,- only a..z A..Z 0..9 '-' and no '-' as last char
  Blynk.begin("Personalized-HostName");
    Blynk.run();
This is the link to Blynk
Blynk IoT Platform
Blynk was designed for the Internet of Things. It can control hardware remotely, it can display sensor data, it can store data, visualize it and do many other cool things.
You can install and use Local Blynk Server (RPi Zero W, 3B+, 4, Laptop, PC, etc) to have full control.
The Server source code is in Public Domain and written in Java. You can download, compile and use to be sure having full control.
Use Local Blynk Server
Blynk Server
Blynk Server Source Code
