BMA180 Control Servo, but servo speed is slow
Hi, i have make servo controller using BMA180 accelerometer. This sensor is in this board:
I successfully control two servo, but the problem is my program make servo move slow, it is not responsive. Is it because I using Map function?
This is my complete code:
#include <Wire.h>
#include <Servo.h>
Servo pitch;
Servo roll;
  pitch.attach(A0);
  roll.attach(A1);
  Wire.begin();
  Serial.println("Demo started, initializing sensors");
  AccelerometerInit();
  Serial.println("Sensors have been initialized");
void AccelerometerInit()
  Wire.beginTransmission(0x40); // address of the accelerometer
  // reset the accelerometer
  Wire.write(0x10);
  Wire.write(0xB6);
  Wire.endTransmission();
  delay(10);
  // low pass filter, range settings
  Wire.write(0x0D);
  Wire.write(0x10);
  Wire.write(0x20); // read from here
  Wire.requestFrom(0x40, 1);
  byte data = Wire.read();
  Wire.write(0x20);
  Wire.write(data & 0x0F); // low pass filter to 10 Hz
  Wire.write(0x35); // read from here
  data = Wire.read();
  Wire.write(0x35);
  Wire.write((data & 0xF1) | 0x04); // range +/- 2g
  Wire.write(0x02); // set read pointer to data
  Wire.requestFrom(0x40, 6);
  // read in the 3 axis data, each one is 16 bits
  // print the data to terminal
  Serial.print("Accelerometer: X = ");
  short data = Wire.read();
  data += Wire.read() << 8;
  Serial.print(data);
  data=constrain(data,-15000, 15000);
  data = map(data, -15000, 15000, 0, 179);     // scale it to use it with the servo (value between 0 and 179)
  pitch.write(data);
  Serial.print(" , Y = ");
  data = Wire.read();
  Serial.print(data);
  roll.write(data);
//The Z Axis is not used
  Serial.print(" , Z = ");
  data = Wire.read();
  Serial.print(data);
Thank You…
We don't know what delays are in those roll and pitch objects you are accessing.
Try adding comments at the start of that line, so they don't run, and see how the speed works. It is unlikely that the "map()" function is the issue.
Get the millis() value at the start and end of each cycle of loop(), and calculate the difference. How often is loop() running ?
Where i must adding comments?
What it mean? it's always looping..
You are complaining about slow response speed ?
One possibility is that your system is working properly, but your expectation of how it should work, is wrong.
The other possibility is that it is not working properly. If you think it is "slow", or taking too long to respond, you need to check for operations which your program is doing, which are either inherently time-consuming, or which are subject to some long delay while they are "waiting" for something, which may or may not be happening.
There is nothing "slow" in the code you have shown us.
What we cannot see, is the code for the roll and pitch objects, on which you are calling functions. Maybe the person who wrote those functions put a long delay() in them, to allow for the time it takes for the servo to re-position itself. Who knows ? We don't. We can't see how those objects are implemented.
My previous suggestion was to make those lines a comment, so they don't get executed. Put two slash characters at the start of the line, and the compiler will ignore it. Like this
//  pitch.set(pwm_value);    //  this line will do nothing
See if loop() runs faster.
The other suggestion, is to see how often loop() actually runs. See how many milliseconds it takes. If loop() is running in a couple of milliseconds, then your system is not really "slow". If loop() is taking hundreds of milliseconds, then there is a delay hidden in there, somewhere.
The other thing to be aware of, is that if the device is not moving, there won't be much acceleration, and you should not expect to see much movement. What are you actually expecting this device to achieve ?
OK michinyon , i will try it again..
