BME280 and MPU6050 data logger
hello people
I got a small problem. I have written this code a long time ago an I don’t know which pins numbers etc I use, I want to revisit this project an improve on it can one of you guide me how I can retrieve the data and proceed with this project.
kind regards pacmanpck
BME280_and_MPU6050_data_logger.ino (3.43 KB)
@pacmanpck
Your topic was Moved to it’s current location / section as it is more suitable.
Could you also take a few moments to Learn How To Use The Forum.
Other general help and troubleshooting advice can be found here.
first of al thank you for your on reaction. how can ik move it to a better location. you told me you where missing some data to what precisely are you referring because you know the sensor I referred them in the title the only thing you perhaps didn't know that I use a Arduino NANO is this enough information for you on this time
OP’s code
#include <Wire.h>
#include "BlueDot_BME280.h"
#include <MPU6050_tockn.h>
#include <SD.h>
#include <SPI.h>
BlueDot_BME280 bme280 = BlueDot_BME280();
MPU6050 mpu6050(Wire);
long timer = 0;
int chipselect = 4;
File Data;
  if (bme280.init() != 0x60)
    Serial.println(F("Ops! BME280 could not be found!"));
    while(1);
    Serial.println(F("BME280 detected!"));
  Wire.begin();
  mpu6050.begin();
  mpu6050.calcGyroOffsets(true);
  pinMode(10,OUTPUT);
  SD.begin(chipselect);
  Data = SD.open("DATALOG.txt",FILE_WRITE);
 if (Data)  {
   Serial.print(F("Duration in Seconds:\t\t"));
   Serial.println(float(millis())/1000);
   Serial.print(F("Temperature in Celsius:\t\t"));
   Serial.println(bme280.readTempC());
   Serial.print(F("Humidity in %:\t\t\t"));
   Serial.println(bme280.readHumidity());
   Serial.print(F("Pressure in hPa:\t\t"));
   Serial.println(bme280.readPressure());
   Serial.print(F("Altitude in Meters:\t\t"));
   Serial.println(bme280.readAltitudeMeter());
    mpu6050.update();
  if(millis() - timer > 1000){
    Serial.println("=======================================================");
    Serial.print("temp : ");Serial.println(mpu6050.getTemp());
    Serial.print("accX : ");Serial.print(mpu6050.getAccX());
    Serial.print("\taccY : ");Serial.print(mpu6050.getAccY());
    Serial.print("\taccZ : ");Serial.println(mpu6050.getAccZ());
    Serial.print("gyroX : ");Serial.print(mpu6050.getGyroX());
    Serial.print("\tgyroY : ");Serial.print(mpu6050.getGyroY());
    Serial.print("\tgyroZ : ");Serial.println(mpu6050.getGyroZ());
    Serial.print("accAngleX : ");Serial.print(mpu6050.getAccAngleX());
    Serial.print("\taccAngleY : ");Serial.println(mpu6050.getAccAngleY());
    Serial.print("gyroAngleX : ");Serial.print(mpu6050.getGyroAngleX());
    Serial.print("\tgyroAngleY : ");Serial.print(mpu6050.getGyroAngleY());
    Serial.print("\tgyroAngleZ : ");Serial.println(mpu6050.getGyroAngleZ());
    Serial.print("angleX : ");Serial.print(mpu6050.getAngleX());
    Serial.print("\tangleY : ");Serial.print(mpu6050.getAngleY());
    Serial.print("\tangleZ : ");Serial.println(mpu6050.getAngleZ());
    Serial.println("=======================================================\n");
    timer = millis();
  delay(200);
Data.print(bme280.readTempC());
Data.print(",");
Data.print(bme280.readHumidity());
Data.print(",");
Data.print(bme280.readPressure());
Data.print(",");
Data.print(bme280.readAltitudeMeter());
Data.print(",");
Data.print(mpu6050.getTemp());
Data.print(",");
Data.print(mpu6050.getAccX());
Data.print(",");
Data.print(mpu6050.getAccY());
Data.print(",");
Data.print(mpu6050.getAccZ());
Data.print(",");
Data.print(mpu6050.getGyroX());
Data.print(",");
Data.print(mpu6050.getGyroY());
Data.print(",");
Data.print(mpu6050.getGyroZ());
Data.print(",");
Data.print(mpu6050.getAccAngleX());
Data.print(",");
Data.print(mpu6050.getAccAngleY());
Data.print(",");
Data.print(mpu6050.getGyroAngleX());
Data.print(",");
Data.print(mpu6050.getGyroAngleY());
Data.print(",");
Data.print(mpu6050.getGyroAngleZ());
Data.print(",");
Data.print(mpu6050.getAngleX());
Data.print(",");
Data.print(mpu6050.getAngleY());
Data.print(",");
Data.println(mpu6050.getAngleZ());
Data.close();
PLEASE USE CODE TAGS
I don't post these links for no reason so take advantage of them !
my sincere apologies for that I've read it a couple of times now and now I understand we'll see English is not my native language and I'm also a very heavy dyslexia so that might explain sumo the problems you encounter now again my sincere apologies for that I will delete the last post if that's possible therefore I shall recap it again if I fail again I will do the same thing and try again until I succeed
som time has passed since we lost talked since that time I've rewritten the complete code however I think I got further this time but there are a few things still wrong and I can't figure out what would you be so kind to help me I have included a picture of the errors I keep getting and I have added in text the code
#include <Wire.h>
#include <SD.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BME280.h>
const int chipSelect = 4;
#define BME_SCK 13
#define BME_MISO 12
#define BME_MOSI 11
#define BME_CS 10
#define SEALEVELPRESSURE_HPA (1013.25)
long timer = 0;
Wire.begin();
MPU6050.begin();
mpu6050.calcGyroOffset(true);
while(!Serial) {
  ; //wait for serial port to connect. needed for native USP port
Serial.println("card initialized.");
while(!Serial);    // time to get serial running
  Serial.println(F("BME280 test"));
  unsigned status;
    status = bme.begin();
    if (!status) {
        Serial.println("Could not find a valid BME280 sensor, check wiring, address, sensor ID!");
        Serial.print("SensorID was: 0x"); Serial.println(bme.sensorID(),16);
        Serial.print("        ID of 0xFF probably means a bad address, a BMP 180 or BMP 085\n");
        Serial.print("   ID of 0x56-0x58 represents a BMP 280,\n");
        Serial.print("        ID of 0x60 represents a BME 280.\n");
        Serial.print("        ID of 0x61 represents a BME 680.\n");
        while (1) delay(10);
   Serial.println("-- Default Test --");
    delayTime = 1000;
String dataSring = "";
for (int analogPin = 0; analogPin < 3; analogpin++) {
  int sensor = analogRead(analogpin)
  dataString += String(sensor);
   if (analogPin < 2) {
      dataString += ",";
 File dataFile = SD.open("datalog.txt", FILE_WRITE);
if (dataFile) {
    dataFile.println(dataString);
    dataFile.close();
    // print to the serial port too:
    Serial.println(dataString);
  // if the file isn't open, pop up an error:
  else {
    Serial.println("error opening datalog.txt");
    Serial.print("Temperature = ");
    Serial.print(bme.readTemperature());
    Serial.println(" *C");
    Serial.print("Pressure = ");
    Serial.print(bme.readPressure() / 100.0F);
    Serial.println(" hPa");
    Serial.print("Approx. Altitude = ");
    Serial.print(bme.readAltitude(SEALEVELPRESSURE_HPA));
    Serial.println(" m");
    Serial.print("Humidity = ");
    Serial.print(bme.readHumidity());
    Serial.println(" %");
    if(millis() - timer > 500{
    timer = millis();
    delay(200);
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.close();
@pacmanpck
We do have some other language options available.
if you would like your post moved please use the "report to moderator" option
thank you for that for now I wil keep to English I think I get a bigger audience if I ask a question was the provided information now wel oké to work with
Ok, I will try a reply again. My last one was lost as I was apparently logged out, and the message was not accepted.
Please look thru this to my <<<<< comments
#include <Wire.h>
#include <SD.h>
#include <SPI.h>
const int chipSelect = 4;  <<<< could be byte, value is <=255
#define BME_SCK 13
#define BME_MISO 12
#define BME_MOSI 11
#define BME_CS 10
long timer = 0;  <<<< should be unsigned long, that is what millis(), micros() are returning
Serial.begin(9600);   <<<< why so slow? Serial Monitor works well at 115200
Wire.begin();
MPU6050.begin();
while(!Serial) {                   <<<<< This section is not needed if your processor does nat USB built in,
  ; //wait for serial port to connect. needed for native USP port   <<<<< such as 328P, 1284P, 2560
}   <<<<< do a CTRL-T in the IDE (Tools:Autoformat), it will show you have too many }. Fix that.
  unsigned status;
    if (!status) {
    delayTime = 1000;   <<<< what is this doing? Data type is not declared, and it assigns a value, that is never used.
String dataSring = "";   <<<< variable name does not match spelling used elsewhere
  int sensor = analogRead(analogpin)                  <<<<< missing a ; here
      dataString += ",";
if (dataFile) {
    dataFile.close();
  else {
    { <<<<<  What is this for?
    timer = millis();  <<<<< are you trying to print all the stuff every 1/2 second (500ms)? This millis() will be well after the millis() above all the Serial.print()s above, especially at 9600
    delay(200);  <<<<< What's delay for? You are already limiting things to every 500+ms, or will be once you get the { } pairings correct.
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.print(",");
Data.close();
Another issue is that you have no declaration of an MPU6050 object. Looking at a GitHub example I see:
thank all of you for your tips and tricks however there are still a few complications if you would be so kind to look at it again that woud be great I have edit the code
#include <Wire.h>
#include <SD.h>
#include <SPI.h>
const int chipSelect = 255;
#define BME_SCK 13
#define BME_MISO 12
#define BME_MOSI 11
#define BME_CS 10
long timer = 0; // <<<< should be unsigned long, that is what millis(), micros() are returning
  Wire.begin();
  mpu6050.begin();
  //while(!Serial) {                   <<<<< This section is not needed if your processor does nat USB built in,
//Serial.println("card initialized.");
//while(!Serial);    // time to get serial running
Adafruit_BME280 bme; // I2C
//Adafruit_BME280 bme(BME_CS); // hardware SPI
//Adafruit_BME280 bme(BME_CS, BME_MOSI, BME_MISO, BME_SCK); // software SPI
//  Serial.println(F("BME280 test"));
//}   <<< << do a CTRL - T in the IDE (Tools: Autoformat), it will show you have too many } . Fix that.
unsigned status;
if (!status) {
  Serial.print("SensorID was: 0x"); Serial.println(bme.sensorID(), 16);
// delayTime = 1000;   <<<< what is this doing? Data type is not declared, and it assigns a value, that is never used.
  String dataSring = "";   <<< < variable name does not match spelling used elsewhere
    int sensor = analogRead(analogpin);
      dataString += ",";
  if (dataFile) {
    dataFile.close();
  else {
  //{ <<<<<  What is this for?
  if (millis() - timer > 500{
    Serial.print("temp : "); Serial.println(mpu6050.getTemp());
    Serial.print("accX : "); Serial.print(mpu6050.getAccX());
    Serial.print("\taccY : "); Serial.print(mpu6050.getAccY());
    Serial.print("\taccZ : "); Serial.println(mpu6050.getAccZ());
    Serial.print("gyroX : "); Serial.print(mpu6050.getGyroX());
    Serial.print("\tgyroY : "); Serial.print(mpu6050.getGyroY());
    Serial.print("\tgyroZ : "); Serial.println(mpu6050.getGyroZ());
    Serial.print("accAngleX : "); Serial.print(mpu6050.getAccAngleX());
    Serial.print("\taccAngleY : "); Serial.println(mpu6050.getAccAngleY());
    Serial.print("gyroAngleX : "); Serial.print(mpu6050.getGyroAngleX());
    Serial.print("\tgyroAngleY : "); Serial.print(mpu6050.getGyroAngleY());
    Serial.print("\tgyroAngleZ : "); Serial.println(mpu6050.getGyroAngleZ());
    Serial.print("angleX : "); Serial.print(mpu6050.getAngleX());
    Serial.print("\tangleY : "); Serial.print(mpu6050.getAngleY());
    Serial.print("\tangleZ : "); Serial.println(mpu6050.getAngleZ());
    timer = millis();  <<< << are you trying to print all the stuff every 1 / 2 second (500ms) ? This millis() will be well after the millis() above all the Serial.print()s above, especially at 115200
    Data.print(",");
    Data.print(",");
    Data.print(",");
    Data.print(",");
    Data.print(",");
    Data.print(",");
    Data.print(",");
    Data.print(",");
    Data.print(",");
    Data.print(",");
    Data.print(",");
    Data.print(",");
    Data.print(",");
    Data.print(",");
    Data.print(",");
    Data.print(",");
    Data.print(",");
    Data.print(",");
    Data.close();
unsigned status;
unsigned what? byte, int, long?
Did you try CTRL-T?
I did, it still shows you have too many right curly braces.
Go thru and make sure each { has a mating }, and they encompass what you are expecting.
You can click your cursor next to a } and then use the scroll bar to work back and find it's mate.
hello people after almost 3 days of continuous coding and troubleshooting I have figured it out so I'm in a quad good mood however there is another problem I can see only one of the sensors I can read only one of the values while I still need both of the values is there who has encountered this problem before and can you give me a tip or something below this I've added a picture in the code itself you can see for yourself why it stopped halfway because I'm out of ideas
#include <Wire.h>
#include <SPI.h>
#include <SD.h>
#include <Adafruit_BMP280.h>
#define BME_SCK 13
#define BME_MISO 12
#define BME_MOSI 11
#define BME_CS 10
Adafruit_BMP280 bme; // I2C
//Adafruit_BMP280 bme(BMP_CS); // hardware SPI
//Adafruit_BMP280 bme(BMP_CS, BMP_MOSI, BMP_MISO, BMP_SCK);
  Wire.begin();
  mpu6050.begin();
Serial.println(F("BMP280 test"));
if (!bme.begin(0x76)) {
Serial.println("Could not find a valid BMP280 sensor, check wiring!");
while (1);
    Serial.print(bme.readPressure());
    Serial.println(" Pa");
    Serial.print("Approx altitude = ");
    Serial.print(bme.readAltitude(1014.25)); // this should be adjusted to your local forcase
    delay(2000);
     mpu6050.update();
