BME280 sensor, shortening output
Hi all.
So finally got my BME280 working well, its outputting humidity and temperature values, but I want to remove the point answers.
So rather than 28.3 C its just 28 C and 79.7% Humidity to 79% Humidity.
Any quick way to do it would be grand.
Cheers in advance.
Alan
#include "Seeed_BME280.h"
#include <Wire.h>
BME280 bme280;
  if(!bme280.init()){
    Serial.println("Device error!");
  float pressure;
  //get and print temperatures
  Serial.print("Temp: ");
  Serial.print(bme280.getTemperature());
  Serial.println("C");
  //get and print atmospheric pressure data
  Serial.print("Pressure: ");
  Serial.print(pressure = bme280.getPressure());
  Serial.println("Pa");
  //get and print altitude data
  Serial.print("Altitude: ");
  Serial.print(bme280.calcAltitude(pressure));
  Serial.println("m");
  //get and print humidity data
  Serial.print("Humidity: ");
  Serial.print(bme280.getHumidity());
  Serial.println("%");
When printing floats you can specify the number of digits after the decimal with,
Serial.print(someFloat, decimal_places);
For instance, to print temperature with no decimals:
Serial.print(bme280.getTemperature(), 0);
Hi Fungus, great name by the way
I`m actually using the BME280 in conjunction with a Nextion display, tried what you suggested but it did not work and it through up an error.
However you gave me the idea to have a play and this worked!.
Serial.print("t7.txt=");
  Serial.print("\"");
  Serial.print(h, 0);
  Serial.print("\"");
  Serial.write(0xff);
  Serial.write(0xff);
  Serial.write(0xff);
So cheers you helped greatly
Alan
