BME680
Does anybody have experience with this senors? I like using the BME280, and I was pretty thrilled when I learned about the BME680, but looking into it deeper, a few things sound strange to me.
  • For once, since it uses MOX, it doesn't sound as low power as it is advertised.
  • I don't really understand the power modes. Ultra-low power mode seems to consume more than 6 times more energy than low power mode. Is that for cases where my supply cannot even provide 0.9mA? It seems best to disable the gas sensor most of the time and only fire it up occationally to make a reading in 1.4 seconds.
  • Does that even work at least halfway accurately? Adafruit recommends to have it running for half an hour before reading, which pretty much prohibits all long term battery application.
  • Can we expect meaningful readings from an ambient temperature sensor right next to a 320°C hotplate in a tiny package?
datasheet page 19
See pages 8-9 of the datasheet.
ElCaron:
Make sure your solder doesn't melt.
jremington:
Are pointing me to the overall accuracy specification? I don't see any inforamtion about longer pre-heating phases there, however I DO see some references to "new sensor" in the datasheet, indicating that there are long- and maybe short-term differences.
knut_ny:
datasheet page 19
Are you talking about the compensation calculation?
wvmarle:
How am I supposed to understand that?
datasheet page 19 points to warmup period (ca. 30 ms) before reading the sensor.
ElCaron:
The melting point of solder is just below 200°C. At 320°C your sensor may fall off the PCB, assuming it can handle the temperature in the first place (it's almost certainly out of spec).
knut_ny:
I have seen that, but it doesn't tell me if Adafruits info is nonsense or the datasheet is too optimistic.
wvmarle:
Well, you might want to tell that to the Bosch engineers (page 8 of the datasheet linked above)
BME680 data sheet, page 8:
Operational range: min -40°C, max 85°C
So 320°C is indeed out of spec, as I expected already.
wvmarle:
We are talking about the heated gas sensor. On the page I mentioned:
"Heater target temperature
320 °C, constant operation
(VDD ≤ 1.8 V, 25°C)"
"[Peak Supply Current] Occurs within first ms of
switching on the hotplate"
I´ve now started with this sensor, too. It shall replace the BME280. But as far as i can tell, it´s not really usable for battery configurations. It´s the first sensor where i have to use the Adafruit library, because the others don´t work for me. And even without using the gas sensor, it takes about 1 second to update, which is very much. Even without filtering and oversampling, the readings of the Adafruit library are unbelievably slow. I don´t know why.
The next thing is the gas sensor itself. The standard value in the Adafruit library (setGasHeater(320, 150)) isn´t usable at all if the sensor isn´t constantly read. However, it cannot be constantly read when using it on battery. So you have to play with the values. I am using setGasHeater(380, 1200) at the moment. This is giving me round about the same values when read once an hour. every reading is influencing the next reading. For example: If you start the station at 10:50, the second value measured at 11:00 will be off, because the time span of 10 minutes will influence the reading (higher) when all other readings will be between 60 minutes. I assume that this is due to rest heat in the sensor.
The consumption with arduino is 20mA without the heater for about 1 sec + 40mA with the heater for about 1 sec. So you have 30mA in 2 sec which is a constant 0.8mA in a minute when read once an hour. The rest needs about 0.2mA of constant current. So you see, it´s a massive reduction in battery life. Using 9 AA cells (3 in row, 3x parallel) which all together have about 9000mAh (3x3000mAh @ 4.5V), you drop from 1875 days of battery life to 375 using this sensor once an hour.
I haven´t really understood how to use the ultra low power mode and if this could be an alternative, but the normal mode on battery is, in my opinion, crap. The overall power consumption is simply too high.
