Ok folks - does anyone know where the BMI160 chip is located - i can not seem to find it on the board.
Reason for asking is I need to know which way the x-axis and y-axes are oriented (can figure out the z from these two. The axes are usually marked on the board or i can figure it out from the datasheet and the chip orientation myself. I am adding a magnetometer to the mix and but you need to get the axes aligned or adjusted for the Madgwick algorithm to work correctly.
Thanks in advance.
