BMP 085
Hello!
I have a little question to the BMP085. I want to connect the sensor (Sainsmart BMP085) to my Arduino Nano. So I decided to power it with 5V, to connect the SDA port to the A4 port and the SCL to the A5 port. However together with the test script from the library at this website: https://github.com/adafruit/Adafruit-BMP085-Library it did not work. I always get the message: Could not find a valid BMP085 sensor, check wiring! So I don't know what to do and I'm pretty frustrated because I tried everything to get some data from the sensor. Anyway I hope that somebody can help me with this tricky job.
Thank you! Thecrazyhobbyists
Did you try the code that Sainsmart has posted on there website?
Yes, I have tried that code, but nothing is printed on the serial display!
Ok, then start by checking which address the sensor has: http://playground.arduino.cc/Main/I2cScanner
That´s what the code prints:
I2C Scanner
Scanning...
I2C device found at address 0x77  !
done
Now check the code if 0x77 is defined as address.
These are the first two lines of the Sain Smart code (after the comment):
#include <Wire.h>
#define BMP085_ADDRESS 0x77  // I2C address of BMP085
But which code should I use? The Sain Smart or the Adafruit?
Lots of good info HERE:
@ thecrazyhobbist
Did you made any progress? i ordered the same setup to design a barometric detecting parachute release system, therefore i hope to get the bosch sensor to run with the Nano...
Cheers.
I’ve put together this code that I use. Copy and paste it in your IDE and give it a try.
  Bosch Pressure Sensor BMP085 / BMP180 readout routine
  for the Arduino platform.
  Compiled by Leo Nutz
  www.ALTDuino.de
#include <Wire.h>
#define ADDRESS_SENSOR 0x77                 // Sensor address
int16_t  ac1, ac2, ac3, b1, b2, mb, mc, md; // Store sensor PROM values from BMP180
uint16_t ac4, ac5, ac6;                     // Store sensor PROM values from BMP180
// Ultra Low Power       OSS = 0, OSD =  5ms
// Standard              OSS = 1, OSD =  8ms
// High                  OSS = 2, OSD = 14ms
// Ultra High Resolution OSS = 3, OSD = 26ms
const uint8_t oss = 3;                      // Set oversampling setting
const uint8_t osd = 26;                     // with corresponding oversampling delay
float T, P;                                 // Set global variables for temperature and pressure
  Wire.begin();                             // Activate I2C
  Serial.begin(9600);                       // Set up serial port
  init_SENSOR();                            // Initialize baro sensor variables
  delay(100);
  int32_t b5;
  b5 = temperature();                       // Read and calculate temperature (T)
  Serial.print("Temperature: ");
  Serial.print(T, 2);
  Serial.print(" C, ");
  Serial.print(1.8 * T + 32.0, 2);
  Serial.println(" F");
  P = pressure(b5);                         // Read and calculate pressure (P)
  Serial.print("Pressure: ");
  Serial.print(P, 2);
  Serial.print(" mbar, ");
  Serial.print(P * 0.0295299830714, 2);
  Serial.println(" inHg");
  Serial.println("");
  delay(500);                               // Delay between each readout
  Initialize sensor variables
void init_SENSOR()
  ac1 = read_2_bytes(0xAA);
  ac2 = read_2_bytes(0xAC);
  ac3 = read_2_bytes(0xAE);
  ac4 = read_2_bytes(0xB0);
  ac5 = read_2_bytes(0xB2);
  ac6 = read_2_bytes(0xB4);
  b1  = read_2_bytes(0xB6);
  b2  = read_2_bytes(0xB8);
  mb  = read_2_bytes(0xBA);
  mc  = read_2_bytes(0xBC);
  md  = read_2_bytes(0xBE);
  Serial.println("");
  Serial.println("Sensor calibration data:");
  Serial.print(F("AC1 = ")); Serial.println(ac1);
  Serial.print(F("AC2 = ")); Serial.println(ac2);
  Serial.print(F("AC3 = ")); Serial.println(ac3);
  Serial.print(F("AC4 = ")); Serial.println(ac4);
  Serial.print(F("AC5 = ")); Serial.println(ac5);
  Serial.print(F("AC6 = ")); Serial.println(ac6);
  Serial.print(F("B1 = "));  Serial.println(b1);
  Serial.print(F("B2 = "));  Serial.println(b2);
  Serial.print(F("MB = "));  Serial.println(mb);
  Serial.print(F("MC = "));  Serial.println(mc);
  Serial.print(F("MD = "));  Serial.println(md);
  Serial.println("");
  Calcualte pressure readings
float pressure(int32_t b5)
  int32_t x1, x2, x3, b3, b6, p, UP;
  uint32_t b4, b7;
  UP = read_pressure();                         // Read raw pressure
  b6 = b5 - 4000;
  x1 = (b2 * (b6 * b6 >> 12)) >> 11;
  x2 = ac2 * b6 >> 11;
  x3 = x1 + x2;
  b3 = (((ac1 * 4 + x3) << oss) + 2) >> 2;
  x1 = ac3 * b6 >> 13;
  x2 = (b1 * (b6 * b6 >> 12)) >> 16;
  x3 = ((x1 + x2) + 2) >> 2;
  b4 = (ac4 * (uint32_t)(x3 + 32768)) >> 15;
  b7 = ((uint32_t)UP - b3) * (50000 >> oss);
  if(b7 < 0x80000000) { p = (b7 << 1) / b4; } else { p = (b7 / b4) << 1; } // or p = b7 < 0x80000000 ? (b7 * 2) / b4 : (b7 / b4) * 2;
  x1 = (p >> 8) * (p >> 8);
  x1 = (x1 * 3038) >> 16;
  x2 = (-7357 * p) >> 16;
  return (p + ((x1 + x2 + 3791) >> 4)) / 100.0f; // Return pressure in mbar
  Read uncompensated temperature
int32_t temperature()
  int32_t x1, x2, b5, UT;
  Wire.beginTransmission(ADDRESS_SENSOR); // Start transmission to device
  Wire.write(0xf4);                       // Sends register address
  Wire.write(0x2e);                       // Write data
  Wire.endTransmission();                 // End transmission
  delay(5);                               // Datasheet suggests 4.5 ms
  UT = read_2_bytes(0xf6);                // Read uncompensated TEMPERATURE value
  // Calculate true temperature
  x1 = (UT - (int32_t)ac6) * (int32_t)ac5 >> 15;
  x2 = ((int32_t)mc << 11) / (x1 + (int32_t)md);
  b5 = x1 + x2;
  T  = (b5 + 8) >> 4;
  T = T / 10.0;                           // Temperature in celsius
  return b5;
  Read uncompensated pressure value
int32_t read_pressure()
  int32_t value;
  Wire.write(0xf4);                         // Sends register address to read from
  Wire.write(0x34 + (oss << 6));            // Write data
  Wire.endTransmission();                   // SEd transmission
  delay(osd);                               // Oversampling setting delay
  Wire.write(0xf6);                         // Register to read
  Wire.requestFrom(ADDRESS_SENSOR, 3);      // Request three bytes
  if(Wire.available() >= 3)
    value = (((int32_t)Wire.read() << 16) | ((int32_t)Wire.read() << 8) | ((int32_t)Wire.read())) >> (8 - oss);
  return value;                             // Return value
  Read 1 byte from the BMP sensor
uint8_t read_1_byte(uint8_t code)
  uint8_t value;
  Wire.write(code);                               // Sends register address to read from
  Wire.requestFrom(ADDRESS_SENSOR, 1);            // Request data for 1 byte to be read
  if(Wire.available() >= 1)
    value = Wire.read();                          // Get 1 byte of data
  Read 2 bytes from the BMP sensor
uint16_t read_2_bytes(uint8_t code)
  uint16_t value;
  Wire.requestFrom(ADDRESS_SENSOR, 2);            // Request 2 bytes from device
  if(Wire.available() >= 2)
    value = (Wire.read() << 8) | Wire.read();     // Get 2 bytes of data
This is an output example:
AC1 = 7878
AC2 = -1089
AC3 = -14478
AC4 = 31607
AC5 = 24469
AC6 = 20562
B1 = 5498
B2 = 57
MB = -32768
MC = -11075
MD = 2432
Temperature: 23.50 C, 74.30 F
Pressure: 991.38 mbar, 29.28 inHg
Pressure: 991.41 mbar, 29.28 inHg
Guten Tag, Leo
Very good code in your example. Its shows directly how to use the pressure sensor.
May I also put your code on the Arduino-Info.Info WIKI? It does not now have any information on the BMP085 .
Viele Dank..
Hello Terry,
of course, if you think it’s helpful.
Frohe Ostern to you.
Leo
