BMP085 & Datalogger Shield Error
Originally there was an error... but some black magic happened and it's gone. Feel free to move this to wherever approriate.
Read the temperature, pressure, and altitude from a BMP085 barometer - Check
Read the time from the RealTime Clock on a adafruit datalogger shield - Check
Output the data to an SD card and log the data - Check
// Hardware:
// Arduino Duelmilanove (based on the the ATmega328p
// Arduino Datalogging Shield (http://www.adafruit.com/products/1141)/ coin battery included
// BMP085 Barometric Pressure/Temperature/Altitude Sensor (http://www.adafruit.com/products/391)
// SD Card
#include "SD.h"
#include <Wire.h>
#include <Adafruit_BMP085.h>
#include <Adafruit_Sensor.h>
#include "RTClib.h"
Adafruit_BMP085 bmp;     // library for the sensor
RTC_DS1307 RTC;          // library for the Realtime Clock
const int chipSelect = 10; // for the data logging shield, we use digital pin 10 for the SD cs line
  Wire.begin();
  RTC.begin();
  // -----------------------------SD CARD Initialization -------------------- //
  Serial.print("Initializing SD card...");
  // make sure that the default chip select pin is set to
  // output, even if you don't use it:
  pinMode(10, OUTPUT);
  // see if the card is present and can be initialized:
  if (!SD.begin(chipSelect)) {
    Serial.println("Card failed, or not present");
    // don't do anything more:
    return;
  else {
  Serial.println("card initialized.");
  //------------------ Initialize sensor and check for errors -------------------- //
  bmp.begin();
  if(!bmp.begin())
    while(1);
  if (! RTC.isrunning()) {
    RTC.adjust(DateTime(__DATE__, __TIME__));  // Sets the date and time to your computer clock
  // --------------------------------Main Code ---------------------------------- //
void loop(void)
  // ------------------ Create or open a text file "ATLAS" --------------- //
  // Warning: if the text file already exists it may cause an error. To know if
  // the data is writing to the SD card correctly, you should see a flashing red
  // light on the arduino every 1 second (or whatever you set the delay too.
  File logfile = SD.open("ATLAS.txt", FILE_WRITE); //Keep the name short, long ones may cause issues
  // ------------------------- Print the current time --------------------------- //
  DateTime now = RTC.now(); // Determine the current time from the RealTime Clock
  String timeStamp = readTimestamp(now); // Call the readTimestamp function
  logfile.print(timeStamp); //Print time in format DD/MM/YYYY 00:00:00
  //Serial.print(timeStamp); // Print on serial monitor (optional)
  // ----------------------- Call BMP085 for a new reading ---------------------- //
  sensors_event_t event;
  bmp.getEvent(&event);
  if (event.pressure) // Check if arduino is reading the BMP085 sensor
    // ----------------------- Atmospheric pressure in hPa ---------------------- //
    float pressure = event.pressure;
    // ------------------------ Temperature in degrees C ------------------------ //
    float temperature;
    bmp.getTemperature(&temperature);
    // ---- Determine the corresponding altitude given temperature & pressure --- //
    float seaLevelPressure = 1015; // Define your standard sea level pressure (in hPa) for better results
    float altitude = bmp.pressureToAltitude(seaLevelPressure,event.pressure,temperature);
    // Print to SD card
    logfile.print("   ");
    logfile.print(pressure);
    logfile.print("   ");
    logfile.print(temperature);
    logfile.print("   ");
    logfile.print(altitude);
    logfile.println();
    // Print to serial monitor (optional)
    // Serial.print("     ");
    // Serial.print(pressure);
    // Serial.print(temperature);
    // Serial.print(altitude);
    // Serial.println();
  else // If it is not reading a value properly
    // Serial.println("Sensor error");
  logfile.close();  // Close the datafile
  // ---- Change this value to how often you want to write the data to the SD card --- //
  delay(1000); // Wait 1000 milliseconds (or 1 second)
  // ------- This function will write the current time into one single string -------- //
String readTimestamp(DateTime thisTime) {
  // concatenate a string with all the parts of the date and time:
  String result = String(thisTime.day());
  result +="/";
  result +=String(thisTime.month(),DEC);
  result +="/";
  result +=String(thisTime.year(),DEC);
  result +=" ";
  result +=String(thisTime.hour(),DEC);
  result +=":";
  result +=String(thisTime.minute(),DEC);
  result +=":";
  result +=String(thisTime.second(),DEC);
  return result;
Hardware Setup: (Arduino Duelmilanove, BMP085 Pressure Sensor Board, Adafruit Datalogger Shield)
Enjoy!
Nevermind.. figured it out.
Great! A cliff hanger. Will you finish your story?
liudr:
Updated :p, and they all lived happily ever after.. the end.
