BMP085.h and Yùn.
Hi, i have a problem with the library BMP085.h and Yùn.
If i use a arduino UNO and i upload the test code him work well. if I change board (with correct ide setting) dosen't work and i have all data with wrong value (Bridge is deactivated).
I have tried many library for the BMP and all dosen't work when the Brigde is active.
when Bridge is activated all the system seem blocked.
i send in attach the best library bmp that i have found.
BMP085-Arduino-Library-master.zip (4.35 KB)
My fault! my fault! :cold_sweat: I have not read the manual and I have not seen that in Yun SCA and SCL pins are 2 and 3 not 4A and 5A like in UNO.
