Hello,
This is my first Arduino project.
I have a Leonardo and a BMP180, with a 16x2 character LCD.
I have the BMP180 working, with sensible figures coming upon the serial monitor, but I get squiggly things coming up on the LCD (like the ‘divided by’ character and a little star wars figure).
I tried the ‘hello , world’ example and the LCD displays it perfectly.
I am trying to get it to display: ‘Press Temp’ on line 1 and
the measured values on line 2.
I can place a string of my choice in my setup area and it displays just fine, but, as soon as I put it in the Loop area, it goes wrong.
In desperation, I placed the print.lcd command in all sorts of places in the loop, but it didn’t seem to make a difference.
It’s as if the value is in non-printing characters, but it shows up OK in the serial monitor.
What am I doing wrong, please?
I have included my code below:
/* SFE_BMP180 library example sketch
This sketch shows how to use the SFE_BMP180 library to read the
Bosch BMP180 barometric pressure sensor.
Like most pressure sensors, the BMP180 measures absolute pressure.
This is the actual ambient pressure seen by the device, which will
vary with both altitude and weather.
Before taking a pressure reading you must take a temparture reading.
This is done with startTemperature() and getTemperature().
The result is in degrees C.
Once you have a temperature reading, you can take a pressure reading.
This is done with startPressure() and getPressure().
The result is in millibar (mb) aka hectopascals (hPa).
If you’ll be monitoring weather patterns, you will probably want to
remove the effects of altitude. This will produce readings that can
be compared to the published pressure readings from other locations.
To do this, use the sealevel() function. You will need to provide
the known altitude at which the pressure was measured.
If you want to measure altitude, you will need to know the pressure
at a baseline altitude. This can be average sealevel pressure, or
a previous pressure reading at your altitude, in which case
subsequent altitude readings will be + or - the initial baseline.
This is done with the altitude() function.
Hardware connections:
- (GND) to GND
- (VDD) to 3.3V
(WARNING: do not connect + to 5V or the sensor will be damaged!)
You will also need to connect the I2C pins (SCL and SDA) to your
Arduino. The pins are different on different Arduinos:
Any Arduino pins labeled: SDA SCL
Uno, Redboard, Pro: A4 A5
Mega2560, Due: 20 21
Leonardo: 2 3
Leave the IO (VDDIO) pin unconnected. This pin is for connecting
the BMP180 to systems with lower logic levels such as 1.8V
Have fun! -Your friends at SparkFun.
The SFE_BMP180 library uses floating-point equations developed by the
Weather Station Data Logger project: http://wmrx00.sourceforge.net/
Our example code uses the “beerware” license. You can do anything
you like with this code. No really, anything. If you find it useful,
buy me a beer someday.
V10 Mike Grusin, SparkFun Electronics 10/24/2013
// Your sketch must #include this library, and the Wire library.
// (Wire is a standard library included with Arduino.):
#include <SFE_BMP180.h>
#include <Wire.h>
#include “LiquidCrystal.h”
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// You will need to create an SFE_BMP180 object, here called “pressure”:
SFE_BMP180 pressure;
#define ALTITUDE 1655.0 // Altitude of SparkFun’s HQ in Boulder, CO. in meters
// set up the LCD’s number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.setCursor(0, 0);
lcd.print(“Temp Press”);
Serial.println(“REBOOT”);
// Initialize the sensor (it is important to get calibration values stored on the device).
if (pressure.begin())
Serial.println(“BMP180 init success”);
// Oops, something went wrong, this is usually a connection problem,
// see the comments at the top of this sketch for the proper connections.
Serial.println(“BMP180 init fail\n\n”);
while(1); // Pause forever.
char status;
double T,P,p0,a;
// Loop here getting pressure readings every 10 seconds.
// If you want sea-level-compensated pressure, as used in weather reports,
// you will need to know the altitude at which your measurements are taken.
// We’re using a constant called ALTITUDE in this sketch:
Serial.print(“provided altitude: “);
Serial.print(ALTITUDE,0);
Serial.print(” meters, “);
Serial.print(ALTITUDE*3.28084,0);
Serial.println(” feet”);
// If you want to measure altitude, and not pressure, you will instead need
// to provide a known baseline pressure. This is shown at the end of the sketch.
// You must first get a temperature measurement to perform a pressure reading.
// Start a temperature measurement:
// If request is successful, the number of ms to wait is returned.
// If request is unsuccessful, 0 is returned.
status = pressure.startTemperature();
if (status != 0)
// Wait for the measurement to complete:
delay(status);
// Retrieve the completed temperature measurement:
// Note that the measurement is stored in the variable T.
// Function returns 1 if successful, 0 if failure.
status = pressure.getTemperature(T);
if (status != 0)
// Print out the measurement:
Serial.print(“temperature: “);
Serial.print(T,2);
Serial.print(” deg C, “);
Serial.print((9.0/5.0)*T+32.0,2);
Serial.println(” deg F”);
// Start a pressure measurement:
// The parameter is the oversampling setting, from 0 to 3 (highest res, longest wait).
status = pressure.startPressure(3);
if (status != 0)
delay(status);
// Retrieve the completed pressure measurement:
// Note that the measurement is stored in the variable P.
// Note also that the function requires the previous temperature measurement (T).
// (If temperature is stable, you can do one temperature measurement for a number of pressure measurements.)
status = pressure.getPressure(P,T);
if (status != 0)
Serial.print(“absolute pressure: “);
Serial.print(P,2);
Serial.print(” mb, “);
Serial.print(P*0.0295333727,2);
Serial.println(” inHg”);
// The pressure sensor returns abolute pressure, which varies with altitude.
// To remove the effects of altitude, use the sealevel function and your current altitude.
// This number is commonly used in weather reports.
// Parameters: P = absolute pressure in mb, ALTITUDE = current altitude in m.
// Result: p0 = sea-level compensated pressure in mb
p0 = pressure.sealevel(P,ALTITUDE); // we’re at 1655 meters (Boulder, CO)
Serial.print(“relative (sea-level) pressure: “);
Serial.print(p0,2);
Serial.print(p0*0.0295333727,2);
// On the other hand, if you want to determine your altitude from the pressure reading,
// use the altitude function along with a baseline pressure (sea-level or other).
// Parameters: P = absolute pressure in mb, p0 = baseline pressure in mb.
// Result: a = altitude in m.
a = pressure.altitude(P,p0);
Serial.print(“computed altitude: “);
Serial.print(a,0);
Serial.print(a*3.28084,0);
else Serial.println(“error retrieving pressure measurement\n”);
else Serial.println(“error starting pressure measurement\n”);
else Serial.println(“error retrieving temperature measurement\n”);
else Serial.println(“error starting temperature measurement\n”);
delay(5000); // Pause for 5 seconds.
lcd.setCursor(0,1);
lcd.print(P);
Cheers,
John
