BMP280 & Arduino Nano 33 ble
Hello, i am using adafruits bmp280 with my Arduino Nano 33 ble but it does not seem to work.
Error code:
/home/builder/opt/arduino-builder/arduino-builder -compile -core-api-version 10611 -hardware /home/builder/opt/arduino-builder/hardware -hardware /home/builder/.arduino15/packages -tools /home/builder/opt/arduino-builder/tools -tools /home/builder/.arduino15/packages -built-in-libraries /home/builder/opt/libraries/latest -logger humantags -fqbn arduino:mbed:nano33ble -build-cache /tmp -build-path /tmp/706213122/build -verbose -prefs runtime.tools.arm-none-eabi-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-none-eabi-gcc/7-2017q4 -prefs runtime.tools.bossac.path=/home/builder/.arduino15/packages/arduino/tools/bossac/1.9.1-arduino1 -prefs runtime.tools.openocd.path=/home/builder/.arduino15/packages/arduino/tools/openocd/0.10.0-arduino9 -prefs runtime.tools.esptool.path=/home/builder/.arduino15/packages/esp8266/tools/esptool/2.5.0-3-20ed2b9 -prefs runtime.tools.mkspiffs.path=/home/builder/.arduino15/packages/esp8266/tools/mkspiffs/2.5.0-3-20ed2b9 -prefs runtime.tools.nrf5x-cl-tools.path=/home/builder/.arduino15/packages/arduino/tools/nrf5x-cl-tools/9.3.1 -prefs runtime.tools.arduino101load.path=/home/builder/.arduino15/packages/Intel/tools/arduino101load/2.0.1 -prefs runtime.tools.CMSIS-Atmel.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS-Atmel/1.2.0 -prefs runtime.tools.linuxuploader.path=/home/builder/.arduino15/packages/arduino/tools/linuxuploader/1.5.1 -prefs runtime.tools.avr-gcc.path=/home/builder/.arduino15/packages/arduino/tools/avr-gcc/7.3.0-atmel3.6.1-arduino5 -prefs runtime.tools.xtensa-lx106-elf-gcc.path=/home/builder/.arduino15/packages/esp8266/tools/xtensa-lx106-elf-gcc/2.5.0-3-20ed2b9 -prefs runtime.tools.sketchUploader.path=/home/builder/.arduino15/packages/Intel/tools/sketchUploader/1.6.2+1.0 -prefs runtime.tools.arm-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/arm-linux-gcc/4.9.3 -prefs runtime.tools.avrdude.path=/home/builder/.arduino15/packages/arduino/tools/avrdude/6.3.0-arduino8 -prefs runtime.tools.arduinoOTA.path=/home/builder/.arduino15/packages/arduino/tools/arduinoOTA/1.3.0 -prefs runtime.tools.CMSIS.path=/home/builder/.arduino15/packages/arduino/tools/CMSIS/4.5.0 -prefs runtime.tools.flashpack.path=/home/builder/.arduino15/packages/Intel/tools/flashpack/2.0.0 -prefs runtime.tools.i586-poky-linux-uclibc.path=/home/builder/.arduino15/packages/Intel/tools/i586-poky-linux-uclibc/1.6.2+1.0 -prefs runtime.tools.arc-elf32.path=/home/builder/.arduino15/packages/Intel/tools/arc-elf32/1.6.9+1.0.1 -prefs runtime.tools.core2-32-poky-linux.path=/home/builder/.arduino15/packages/Intel/tools/core2-32-poky-linux/1.6.2+1.0 -prefs runtime.tools.x86-linux-gcc.path=/home/builder/.arduino15/packages/arduino/tools/x86-linux-gcc/7.2.0 -prefs runtime.tools.dfu-util.path=/home/builder/.arduino15/packages/arduino/tools/dfu-util/0.9.0-arduino1 -libraries /tmp/706213122/custom -libraries /tmp/706213122/pinned /tmp/706213122/bmp280test
Multiple libraries were found for "Adafruit_Sensor.h"
Used: /home/builder/opt/libraries/latest/adafruit_unified_sensor_1_1_3
Not used: /home/builder/opt/libraries/latest/arduav_1_4_2
Not used: /home/builder/opt/libraries/latest/allthingstalk_lte_m_sdk_1_0_0
Using library adafruit_bmp280_library_2_0_1 at version 2.0.1 in folder: /home/builder/opt/libraries/latest/adafruit_bmp280_library_2_0_1
Using library adafruit_unified_sensor_1_1_3 at version 1.1.3 in folder: /home/builder/opt/libraries/latest/adafruit_unified_sensor_1_1_3
In file included from /tmp/706213122/bmp280test/bmp280test.ino:20:0:
/home/builder/opt/libraries/latest/adafruit_bmp280_library_2_0_1/Adafruit_BMP280.h:40:17: error: conflicting declaration 'arduino::SPIClass SPI'
extern SPIClass SPI; /**< Forward declaration of SPI object */
In file included from /tmp/706213122/bmp280test/bmp280test.ino:19:0:
/home/builder/.arduino15/packages/arduino/hardware/mbed/1.1.2/libraries/SPI/SPI.h:64:25: note: previous declaration as 'arduino::MbedSPI SPI'
extern arduino::MbedSPI SPI;
exit status 1
any help would be greatly appreciated
The Arduino Nano 33 BLE uses mbedOS. There are incompatibilities with some libraries. See whether there is a new version of the library available or whether you can find a compatibility list. Adafruit has quite a lot of documentation and examples. Check their web page and github.
You can also Google the forum with "mbed library issues site:arduino.cc" or similar. I have seen some other post before.
Ok, thanks alot
