abhixs
October 18, 2022, 9:36am
1
Hi guys, i’m trying to use a BMP280 with LED and want to add if condition with pressure, but it is not working ..can you please suggest how to fix this.
My code is:
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_BMP280.h>
#define BMP_SCK (13)
#define BMP_MISO (12)
#define BMP_MOSI (11)
#define BMP_CS (10)
const int ledPin = 13;
Adafruit_BMP280 bmp; // I2C
//Adafruit_BMP280 bmp(BMP_CS); // hardware SPI
//Adafruit_BMP280 bmp(BMP_CS, BMP_MOSI, BMP_MISO, BMP_SCK);
pinMode(ledPin, OUTPUT);
if (!bmp.begin(0x76)) {
Serial.println(F("Could not find a valid BMP280 sensor, check wiring!"));
while (1);
/* Default settings from datasheet. */
bmp.setSampling(Adafruit_BMP280::MODE_NORMAL, /* Operating Mode. */
Adafruit_BMP280::SAMPLING_X2, /* Temp. oversampling */
Adafruit_BMP280::SAMPLING_X16, /* Pressure oversampling */
Adafruit_BMP280::FILTER_X16, /* Filtering. */
Adafruit_BMP280::STANDBY_MS_500); /* Standby time. */
Serial.print(F("Pressure = "));
Serial.print(bmp.readPressure()/100);
Serial.println(" Pa");
Serial.print(pressure); // mm Mercury
float pressure = bmp.readPressure() * 0.00750061683;
if ((pressure * 0.00750061683) >981.70)
// Pressure too high
digitalWrite(ledPin, LOW);
if ((pressure * 0.00750061683) <981.70)
{ // turn LED off:
digitalWrite(ledPin, HIGH);
What does [quote="abhixs, post:1, topic:1043269"]but it is not working[/quote] mean?
What is this supposed to do float pressure = bmp.readPressure() * 0.00750061683; and why do this pressure * 0.00750061683 in the if?
Which Arduino board are you using ?
How precise do you expect a float to be when using that board ?
Why are you multiplying pressure by 0.00750061683 and why are you doing it twice ?
abhixs
October 18, 2022, 9:57am
4
I am using Arduino nano.
it can be precise between 4-5 digit
by mistake i used 0.00750061683 twice, i was looking some examples on google and i copy pasted code from there. I don't have so much idea about this sensor.
So, post your updated code and tell us what you mean by "not working"
I don't suppose that you have tried printing the value that you are testing to see whether it looks reasonable, or have you ?
Hello
Run this tutorial to gain the knowledge.
abhixs
October 18, 2022, 10:04am
7
If condition for LED is not working, i mean when pressure is <981.70 led is not getting on and when pressure is >981.70 led is not getting off.
Updated Code:
#include <Wire.h>
#include <SPI.h>
#define BMP_CS (10)
while (1);
if ((pressure) >981.70)
if ((pressure) <981.70)
{ // turn LED off:
You are still not printing the value that you are testing and have not said what "not working" means
Please help us to help you
Why is the pressure reading being multiplied by 0.00750061683?
Have you done a
Serial.println( pressure );
to see what the result is?
abhixs
October 18, 2022, 10:10am
10
this value i am getting printed
981.70*0.00750061683 = 7.363355542011, quite strange. Also, the LED will not come on. Try removing the *0.00750061683 part.
I've not ever experienced a BMP or BME giving such stable pressure readings as shown in post#10.
abhixs
October 18, 2022, 10:23am
12
Thank you so much, this solved my problem ..thanks a lot again
What solved your problem?
abhixs
October 18, 2022, 10:48am
14
This solved my problem
system
Closed
April 16, 2023, 10:48am
15
