Hello,
I am a newbie and i am using a mega2560 with a bmp280 and a LCD robot shield to teach to my son something about weather..
I noticed that the readings are at least 1,2-1,5 °C higher than a professional thermometer (placed in the same place at the same time of the sensor); i have read the datasheet and it seems that the sensor is auto-heating after some time, so it is necessary to apply a compensation formula as in the Bosch datasheet..
Someone could help me please?
Thanks!
The code i use:
The Arduino Mega 2560 is the only Arduino board with 10k pullup resistors from SDA and SCL to 5V. That could damage the BMP280 when you connect those SDA and SCL directy to the SDA and SCL pins of the BMP280. Your BMP280 could be damaged by now.
stewecar:
I connected the sensor at the 5v pin, so that's the error? Doesn't have a shifting level circuitry? Thanks!
You almost certainly have it on a breakout board as the sensor is about 2x2mm, no lead package. The sensor itself has no such circuitry built in, the breakout board may or may not have it.
Hello,
It's the same model (gy bmp280) that is in a weather station mega2560's project..
Anyway i used it before with a nodemcu lolin at 3,27v and temperature readings were even worse (from 1,4 to 2,2 °C higher).
It could be only a defective one and all my questions are futile..but i was curious that in the Bosch bmp280 datasheet i found some compensation formula that obviously means that something needs to be modified..
Thanks for the replies.
Stefano
If you power that with 5V instead of 3.3V, it gets certainly damaged.
If you connect those SDA and SCL to the Arduino Mega 2560 SDA and SCL it is no longer reliable. I don't know if that will permanent damage it, but it is not okay.
Thanks, so i have now a gy MC Donald fried one
Anyway now i have putted it on a esp8266..pressure readings are OK, temperature at least 1,4 degrees higher..
Thanks again.
Stefano
