Bmw key fob + arduino
Hey everyone! For now im trying to gather theoretical facts regarding my new project to see how plausible it is. For now, i want to retrofit a bmw key fob and key fob holder into my older bmw, but because i need to use all computers and wires from newer bmw, which is expensive and boring, i decided to make my own, and just use parts i want to put in.
So the explanation:
The fob holder has only 3 electronic/electrical components. 1. Circuitry with few resistors, transistors, and few other things, none of which are ICs, and as far as i saw, none of them actually connect to any other 2 components in the key holder. I assume the circuitry is meant for a starter button, because in bmw, starter button and key holder share same ribbon wire, and probably use key holder as sort of a jumper station. The other 2 components are: electro magnet to lock the key in, and an antenna for the immo chip. You can push the key in and it springs back up, like that, you turn the ignition on with no physical button being inside.
Question: can i use the key holder antena to scan, lets say, an arduino rfid chip to work as a new immo, as well as use the antenna as a button? Perhaps measure distance, signal strenght or inductance between antenna and an rfid chip?
Thank you in advance
