Im using the Tinygpsplusplus library on an ESP32
Currrently my BN-880 points north with wires on the right side of unit.
Is there a way to change the orientation so that north (0 deg) is on another side of unit?
Add 180 degrees to the compass reading it produces ?
Sorry im very good at this math.
Can you tell me how I add the 180 deg to it?
There must be a formula
Compass_reading = Compass_reading + 180;
if (Compass_reading > 360) Compass_reading = Compass_reading - 360;
That you
Ill give it a try
Thanks guys
Works Perfect
One more question.
I am totaly new to programing a gps. My question is:
Do I need to calibrate the compass on the bn-880?
well, I'd suggest you read the documentation on it. Usually you can find most relevant information on the summary.
Yes, if it does not produce the expected headings, while you turn slowly around.
