BNO055 doesn't get recognised
Hello everyone!
I can't get the BNO055 to work for me. When I run the I2C-Scanner sketch to find out its address, the arduino can't find it. I connected SDA with the A5-Pin and SCL with with the A4-Pin.
I don't have the Adafruit breakout board but instead this one from aliexpress
goo.gl/Io4iEY
Can someone help me please? i am stuck^^
Did you connect power and ground?
yes of course i connected them.
i was thinking that i maybe have to do something with those solder pads. sadly i didnt found someone using this sensor breakout board
You do have to solder the connections.
For informed help, please read and follow the directions in the "How to use this forum" sticky.
