I have 3 BNO055 boards that I am trying to test as I suspect that they are all bad.
I am trying to run the example sketch Example\Arduino BNO055\sensorapi
And for all 3 boards I get "BNO055 not detected"
My question is,,, Is it only the power connection that the program uses to see if the board is connected or does the program also use the SDA and SCL pins ?
Additionally I have a reading of 6.2v going into vin. Is that too much ?
Has the board been fried ?
hextejas:
Please post a link (using the chain links icon on the forum toolbar to make it clickable) to where you downloaded that BNO055 library from. Or if you installed it using Library Manger (Sketch > Include Library > Manage Libraries in the Arduino IDE or Libraries > Library Manager in the Arduino Web Editor) then say so and state the full name of the library.
hextejas:
Please post a link to where you bought the BNO055 boards from.
The BNO055 board is fine. From what I can tell, you should actually be able to go up to 10 V on the VIN pin without harming anything on the BNO055 board. But your Feather Huzzah might not be:
Connect Vin to the power supply, 3-5V is fine. Use the same voltage that the microcontroller logic is based off of.
There are 10K pullup resistors to VIN on the SDA and SCL lines, so you are exposing the SDA and SCL pins on your Feather Huzzah to 6.2V. You should connect 3.3 V to the VIN pin when using the BNO055 board with a 3.3 V board like the Feather Huzzah. This is the reason Adafruit says "VIN: 3.3-5.0V power supply input" in the documentation for the BNO055 board. Not because the board can't handle more than that, but because those are the voltages used by the microcontrollers it will be connected to.
hextejas:
Probably it's using the SDA and SCL pins. I could be sure if you answered the question about the library. Are you using this one?:
Re the voltage, I am a bit confused. The Feather gets its 5v from the USB connection.
And I happened to have a 6v battery laying around and that is what I an using to power the BNO055. The GNDs are tied together.
The Feather has a voltage regulator connected to the 5 V input that reduces it to 3.3 V. The ESP8266 would be damaged or destroyed if you powered it at 5 V. Similarly, the ESP8266 IO pins are not rated for higher voltages. Some people do use the ESP8266 with 5 V logic levels, though it's controversial whether this will damage the ESP8266. Either way, it's certainly not safe to subject the pins to 6.2 V. Connect the 3.3V pin of the Feather Huzzah to the VIN pin of the BNO055. Remove the connection to the battery.
hextejas:
hextejas:
Yes it is using the Adafruit BNO055 library.
The 6V battery is not in the circuit, how did you connect it.
Have you got the Feather's gnd connected to the BNO055 gnd and the 6V battery gnd?
Tom....
