BNO08x without Cable Connection
Hello,
So I am building a project where an OLED display can print the angles of yaw, pitch, and roll using data from the Adafruti BNO08x. Using the example codes, I could print out the angles on the serial monitor and the OLED display. However, this will only work when I connect it using a cable. Without the cable, it won't show the yaw, pitch, and roll onto the OLED display. I will show my code here, but to my understanding, I think my code is getting stuck somewhere, preventing the printing on the OLED from happening. Can someone help?
Here is my code:
#include <Arduino.h>
// This demo explores two reports (SH2_ARVR_STABILIZED_RV and SH2_GYRO_INTEGRATED_RV) both can be used to give
// quartenion and euler (yaw, pitch roll) angles.  Toggle the FAST_MODE define to see other report.
// Note sensorValue.status gives calibration accuracy (which improves over time)
#include <Adafruit_BNO08x.h>
#include <Wire.h>
#include <Adafruit_GFX.h>
#include <Adafruit_SSD1306.h>
#define SCREEN_WIDTH 128
#define SCREEN_HEIGHT 64
#define OLED_RESET -1
Adafruit_SSD1306 display(SCREEN_WIDTH, SCREEN_HEIGHT, &Wire, OLED_RESET);
// For SPI mode, we need a CS pin
#define BNO08X_CS 36
#define BNO08X_INT 32
// #define FAST_MODE
// For SPI mode, we also need a RESET
#define BNO08X_RESET 34
// but not for I2C or UART
// #define BNO08X_RESET -1
struct euler_t {
  float yaw;
  float pitch;
  float roll;
} ypr;
Adafruit_BNO08x  bno08x(BNO08X_RESET);
sh2_SensorValue_t sensorValue;
#ifdef FAST_MODE
  // Top frequency is reported to be 1000Hz (but freq is somewhat variable)
  sh2_SensorId_t reportType = SH2_GYRO_INTEGRATED_RV;
  long reportIntervalUs = 2000;
#else
  // Top frequency is about 250Hz but this report is more accurate
  sh2_SensorId_t reportType = SH2_ARVR_STABILIZED_RV;
  long reportIntervalUs = 5000;
#endif
void setReports(sh2_SensorId_t reportType, long report_interval) {
  Serial.println("Setting desired reports");
  if (! bno08x.enableReport(reportType, report_interval)) {
    Serial.println("Could not enable stabilized remote vector");
void setup(void) {
  Wire.begin();
  Wire.setClock(400000);
  if (!display.begin(SSD1306_SWITCHCAPVCC, 0x3C)) {
    Serial.println(F("SSD1306 allocation failed"));
    for (;;);
  display.clearDisplay();
  display.setTextSize(1);
  display.setTextColor(SSD1306_WHITE);
  display.setCursor(0, 0);
  display.println(F("Welcome ShivPat!"));
  display.println(F("Code will run shortly..."));
  display.display();
  delay(5000);
  while (!Serial) delay(10);     // will pause Zero, Leonardo, etc until serial console opens
  Serial.println("Adafruit BNO08x test!");
  // Try to initialize!
  // if (!bno08x.begin_I2C()) {
  // if (!bno08x.begin_UART(&Serial1)) {  // Requires a device with > 300 byte UART buffer!
  if (!bno08x.begin_SPI(BNO08X_CS, BNO08X_INT)) {
    Serial.println("Failed to find BNO08x chip");
    while (1) { delay(10); }
  Serial.println("BNO08x Found!");
  setReports(reportType, reportIntervalUs);
  Serial.println("Reading events");
  delay(100);
void quaternionToEuler(float qr, float qi, float qj, float qk, euler_t* ypr, bool degrees = false) {
    float sqr = sq(qr);
    float sqi = sq(qi);
    float sqj = sq(qj);
    float sqk = sq(qk);
    ypr->yaw = atan2(2.0 * (qi * qj + qk * qr), (sqi - sqj - sqk + sqr));
    ypr->pitch = asin(-2.0 * (qi * qk - qj * qr) / (sqi + sqj + sqk + sqr));
    ypr->roll = atan2(2.0 * (qj * qk + qi * qr), (-sqi - sqj + sqk + sqr));
    if (degrees) {
      ypr->yaw *= RAD_TO_DEG;
      ypr->pitch *= RAD_TO_DEG;
      ypr->roll *= RAD_TO_DEG;
void quaternionToEulerRV(sh2_RotationVectorWAcc_t* rotational_vector, euler_t* ypr, bool degrees = false) {
    quaternionToEuler(rotational_vector->real, rotational_vector->i, rotational_vector->j, rotational_vector->k, ypr, degrees);
void quaternionToEulerGI(sh2_GyroIntegratedRV_t* rotational_vector, euler_t* ypr, bool degrees = false) {
  if (bno08x.wasReset()) {
    Serial.print("sensor was reset ");
  if (bno08x.getSensorEvent(&sensorValue)) {
    // in this demo only one report type will be received depending on FAST_MODE define (above)
    switch (sensorValue.sensorId) {
      case SH2_ARVR_STABILIZED_RV:
        quaternionToEulerRV(&sensorValue.un.arvrStabilizedRV, &ypr, true);
      case SH2_GYRO_INTEGRATED_RV:
        // faster (more noise?)
        quaternionToEulerGI(&sensorValue.un.gyroIntegratedRV, &ypr, true);
    static long last = 0;
    long now = micros();
    Serial.print(now - last);             Serial.print("\t");
    last = now;
    Serial.print(sensorValue.status);     Serial.print("\t");  // This is accuracy in the range of 0 to 3
    display.print(F(" Yaw: "));
    display.println(ypr.yaw);
    display.print(F(" Pitch: "));
    display.println(ypr.pitch);
    display.print(F(" Roll: "));
    display.println(ypr.roll);
    display.display();
    Serial.print(ypr.yaw);                Serial.print("\t");
    Serial.print(ypr.pitch);              Serial.print("\t");
    Serial.println(ypr.roll);
Post the other half, the annotated schematic. This very much sounds like a hardware problem. Be sure to show all connections and any other hardware that is connected.
Hey gilshultz, I've never drawn a schematic. Let me try making a diagram to the best of my ability.
@gilshultz I apologize for keeping you waiting. I managed to debug the issue and it was coming from this line and the other serial print lines
It won't run the code until the program gets out of this while loop as shown in the comment as well. However, I would like to ask if you have an application or website I can build schematics because I think it's important I learn how to build Arduino diagrams and schematics.
As far as I can see, you did not mention which board you were using. As you might have figured out now, it is important information for those that try to help :wink:
A lot of people use Kicad. But a pen and paper drawing will be sufficient as well, both for yourself or for publishing on the forum (just make sure that all wiring including all powers and grounds are in there).
KiCad is a great CAD (Computer Aided Design) software package that runs on most platforms. They ask for a voluntary donation but whether you donate or not the software is the same. Go on line and look for KiCad tutorials etc there are a lot of them and many for each release. This will take some time to master it but I got my first schematic the second evening.
Using CAD makes it look professional and yes it does have a rules check to check your work.
