Board and Library management constraints? contd
Continuing the discussion from Using the library and board manager?:
Bob,
I had three or 4 boards in there before I first saw the problem and re-installing using IDE 1.8.19 cleared the issue where I could not see the AVR Arduino 2650 MegaPi board I was seeking.
The library that was in there in File Preferences last at that time was one for a DIY 4 in 1 Multiprotocol module with a STM processor found now in many RC Transmitters Plug in modules and I had been changing and re-compiling it successfully. .. I think i can retrieve it if needed later but don't need it right now.. Re-Installing the IDE 1.8.19 blew it away but DID allow me to then see and add the Arduino 2650 board I was seeking to add a few days ago. along with a "MakeBlockDrive" library and example code.
in between the lines here I think you are implying that I should not have had any issue adding any number of different Boards and their custom library's and that this was a temporary fluke.. Ok I'll buy that. Stuff happens..
I've just gone back to the Board's manufacturer (Makeblock) to see if there really is a library and alternate firmware for the Ultimate 2.0 model robot that they make that I'm simply unable to find... it uses the same MegaPi 2650 based processor board but is not in the library I can find.
In the mean time I have about a hundred or more "Board's listed right now, including the ones I need.. so I assume (based on your indirect implication) that there should be no constraints in adding new custom libraries or boards in the future.
If anyone is aware of a tutorial that addresses this "no-find" issue directly and can clarify any specific IDE 1.8.19 constraints and work arounds needed to locate and load custom libraries and supported boards.. Please advise with a link to it..
Thanks Again.. jimS
Please provide a detailed description of the issue.
Correct
Please provide a detailed description of what you mean by this.
What do you mean by "library"? Any Arduino user past their first day or two has used libraries, so this might seem like a dumb question I am asking, but sometimes people use the term "library" to refer to things that are not actually libraries, and this can cause a lot of confusion. So I want to make sure I understand.
Nice!
Correct.
The one problem that can occur is header file name collisions. When you have multiple libraries which contain a header file name that matches an #include directive in your sketch program. For example:
#include <Foo.h>
The Arduino IDE must pick only one of those multiple libraries to use. It is pretty smart about this, so it gets it right most of the time. But when it doesn't pick the right library, this can cause a confusing situation.
That collision might happen even with only a couple of libraries installed, but it becomes statistically more likely the more libraries you install. It's not something to be worried about, and the Arduino IDE even tells you when this has happened, but you are asking about whether there are any potential issues with adding more libraries, so there is your answer.
We need you to provide a detailed and precise description of the "no-find" issue. I don't think anyone here is sure what exactly is the problem you had because you have been quite vague about it.
Continuing the discussion from Board and Library management constraints? contd:
in0
thanks for trying to help here.. I don't believe I can describe this "no-find" problem which appears now to be resolved with the boards manager, but still persists with a no-find library, until I hear from the board's manufacturer since it was their support that started I should install the library for their "ultimate 2.0 " robot to be able to customize this robot .. but they never gave me the name of the .zip file for it. Perhaps it doesn't exist, and since these guys are native Chinese and I can't totally understand much of their sketchy documentation either I may have mis understood something . I need to wait for their reply and a little clarity since looking for it by variations of the board's name appears to be impossible. By the way I did decide to try out the new 2.0 RC3 IDE and was able to add all the Arduino AVR and ESP32 boards and libraries I need for now without any issue yesterday.. I'm glad to hear header file name collisions may be a factor, but I need to load the library by name 1st. and I can't load it if the library manager can't find it. Thanks again .. jimS
If you post the full and exact text of the reply from support, we might be able to decipher it for you. I don't know whether it is the case here, but too often I find that 3rd party manufacturers of products using the Arduino framework and tools don't understand how these things work, and so give confusing, problematic, obsolete, or incorrect installation and usage instructions to their users.
So sometimes it takes someone with an in depth knowledge of the subject to read between the lines and adapt the bad manufacturer instructions into something that follows modern best practices.
I agree , sorry for the long delay in my reply but I moved on to a different Robot and will post some detail on its somewhat similar issues there.. Thanks
