Hi., Re: Board_Detect
I have been attempting to run Nick Gammons Arduino-Sketches-Master series. I ran a number of Atmega328’s on my breadboard. All but one failed and all delivered a similar message as the one below. The successful chip later failed on a second or third run through Arduino_Board_Detect it then delivered the following textual answer which was derived from using a virgin ATMega328P-PU that on first pass was shown to be as manufactured It was supplied by RSComponents [No innuendo implied]:
Board detector
Atmega chip detector.
Written by Nick Gammon.
Version 1.17
Compiled on Nov 9 2015 at 09:06:08 with Arduino IDE 10605.
Attempting to enter ICSP programming mode …
Failed to enter programming mode. Double-check wiring!
Programming mode off.
I then attempted the signature program and all failed delivering up the following the following:
Signature detector.
Compiled on Nov 9 2015 at 08:58:40 with Arduino IDE 10605.
Signature = 1E 95 14
Fuses
Low = FF High = DA Ext = FD Lock = CF
Unrecognised signature.
I have one further VIRGIN 328 but am reluctant to try it without knowing that I will not wreck it, all given that is the case with the other new and virgin but failed one
The wring was not changed either before or after receipt of the successfully detected chip.
The board that powered each experiment was the same one, namely and Arduino clone “Duemilanove Funduino”.
Can any one read the reason or corrective measure out of the explanations provided please.
I have searched in vain throughout all the relevant forums, apologies if I have missed some simple cure.
Chris Spreckley.
