The following code works fine on except that when changing to a Wemos D1 mini board, the deep sleep does not work as it used to with my NodeMCU
/* HTTPS on ESP8266 with follow redirects, chunked encoding support
Version 3.0
Author: Sujay Phadke
Github: @electronicsguy
Copyright (C) 2018 Sujay Phadke <electronicsguy123@gmail.com>
All rights reserved.
Example Arduino program
#include "DHTesp.h"
#include <ESP8266WiFi.h>
#include "HTTPSRedirect.h"
#include <Wire.h>
#include <SPI.h>
#include <Adafruit_Sensor.h>
#include <Adafruit_BMP280.h>>
#include "cedentials.h"
float temperature;
float humidity;
float pressure;
#define ALTITUDE 19.812 // Altitude in Hamilton, NZ
#define SLEEP_LENGTH 60*30
#define I2C_ADDRESS 0x76
Adafruit_BMP280 bme;
DHTesp dht;
const char* host = "script.google.com";
const int httpsPort = 443;
// Write to Google Spreadsheet
String url = String("/macros/s/") + GScriptId + "/exec?";
HTTPSRedirect* client = nullptr;
dht.setup(D5, DHTesp::DHT11);
Serial.println(F("BMP280 test connection"));
Serial.flush();
if (!bme.begin(I2C_ADDRESS)) {
Serial.println(F("BMP280 not connected"));
Serial.flush();
while (1);
Serial.println("Success!");
Serial.println("");
Serial.print("Connecting to wifi: ");
Serial.println(ssid);
// flush() is needed to print the above (connecting...) message reliably,
// in case the wireless connection doesn't go through
Serial.flush();
WiFi.begin(ssid, password);
Serial.print(".");
Serial.println("");
Serial.println("WiFi connected");
Serial.println("IP address: ");
// Use HTTPSRedirect class to create a new TLS connection
client = new HTTPSRedirect(httpsPort);
client->setInsecure();
client->setPrintResponseBody(true);
client->setContentTypeHeader("application/json");
Serial.print("Connecting to ");
Serial.println(host);
// Try to connect for a maximum of 5 times
bool flag = false;
for (int i = 0; i < 5; i++) {
int retval = client->connect(host, httpsPort);
if (retval == 1) {
flag = true;
Serial.println("Connection failed. Retrying...");
if (!flag) {
Serial.print("Could not connect to server: ");
Serial.println("Exiting...");
return;
temperature = bme.readTemperature();
Serial.print("Temperature: "); Serial.println(temperature);
humidity = dht.getHumidity();
Serial.print("Humidity: "); Serial.println(humidity);
pressure = bme.readPressure(); // pressure in Pa
Serial.print("Pressure: "); Serial.println(pressure);
// Send memory data to Google Sheets
String urlFinal = url + "Temperature=" + temperature + "&Humidity=" + humidity + "&Pressure=" + pressure;
Serial.print("urlFinal "); Serial.println(urlFinal);
client->GET(urlFinal, host, false);
// delete HTTPSRedirect object
delete client;
client = nullptr;
delay(3000);
//ESP.deepSleep(10000000);
ESP.deepSleep(SLEEP_LENGTH * 1000000,WAKE_RF_DEFAULT); // // deepSleep time is defined in microseconds. Multiply seconds by 1e6
delay(100);
Previously I could have the system set up as per the schematic (i.e. with D0 and RSTshorted) and the board would power up. With the Wemos D1 mini I need to press the reset button once after power-up or I need to boot it without D0 connected to RST, connecting it after powering up.
What is different between the two boards with respect to Deep Sleep? Could I add some components in the D0 - RST link so that there is a second delay in the connection being formed?
