Board keeps resetting cpu after uploading code
As soon as the code finishes uploading, it says "cpu reset." in the output. It starts printing out some dots as it tries to connect to the wifi (as instructed) but it never manages to get far enough to actually do anything. I have attatched the code incase there is anything wrong with it.
I am using the arduino nano 33 iot.
#include <WiFi.h>
#include <Wire.h>
const char* ssid = "replace"; // Replace with your network SSID (name)
const char* password = "replace"; // Replace with your network password
const int MPU = 0x68; // MPU6050 I2C address
float AccX, AccY, AccZ;
float GyroX, GyroY, GyroZ;
float accAngleX, accAngleY, gyroAngleX, gyroAngleY, gyroAngleZ;
float roll, pitch, yaw;
float AccErrorX, AccErrorY, GyroErrorX, GyroErrorY, GyroErrorZ;
float elapsedTime, currentTime, previousTime;
int c = 0;
  // Start the serial communication to display the connection status
  Serial.begin(115200); //115200 baud
  delay(100);
  // Attempt to connect to WiFi network
  Serial.print("Connecting to ");
  Serial.println(ssid);
  WiFi.begin(ssid, password);
  // Wait until the board is connected to the WiFi network
    Serial.print(".");
  //if connection failed
  if (WiFi.status() != WL_CONNECTED) {
    Serial.println("Failed to connect to WiFi!");
    return;
  // When connected, print the IP address
  Serial.println("");
  Serial.println("WiFi connected.");
  Serial.println("IP address: ");
 Serial.begin(19200);
  Wire.begin();                      // Initialize communication
  Wire.beginTransmission(MPU);       // Start communication with MPU6050 // MPU=0x68
  Wire.write(0x6B);                  // Talk to the register 6B
  Wire.write(0x00);                  // Make reset - place a 0 into the 6B register
  Wire.endTransmission(true);        //end the transmission
  // Configure Accelerometer Sensitivity - Full Scale Range (default +/- 2g)
  Wire.write(0x1C);                  //Talk to the ACCEL_CONFIG register (1C hex)
  Wire.write(0x10);                  //Set the register bits as 00010000 (+/- 8g full scale range)
  // Configure Gyro Sensitivity - Full Scale Range (default +/- 250deg/s)
  Wire.write(0x1B);                   // Talk to the GYRO_CONFIG register (1B hex)
  Wire.write(0x10);                   // Set the register bits as 00010000 (1000deg/s full scale)
  delay(20);
  // Call this function if you need to get the IMU error values for your module
  calculate_IMU_error();
  delay(20);
  // === Read accelerometer data === //
  Wire.write(0x3B); // Start with register 0x3B (ACCEL_XOUT_H)
  Wire.endTransmission(false);
  Wire.requestFrom(MPU, 6, true); // Read 6 registers total, each axis value is stored in 2 registers
  //For a range of +-2g, we need to divide the raw values by 16384, according to the datasheet
  AccX = (Wire.read() << 8 | Wire.read()) / 16384.0; // X-axis value
  AccY = (Wire.read() << 8 | Wire.read()) / 16384.0; // Y-axis value
  AccZ = (Wire.read() << 8 | Wire.read()) / 16384.0; // Z-axis value
  // Calculating Roll and Pitch from the accelerometer data
  accAngleX = (atan(AccY / sqrt(pow(AccX, 2) + pow(AccZ, 2))) * 180 / PI) - 0.58; // AccErrorX ~(0.58) See the calculate_IMU_error()custom function for more details
  accAngleY = (atan(-1 * AccX / sqrt(pow(AccY, 2) + pow(AccZ, 2))) * 180 / PI) + 1.58; // AccErrorY ~(-1.58)
  // === Read gyroscope data === //
  previousTime = currentTime;        // Previous time is stored before the actual time read
  currentTime = millis();            // Current time actual time read
  elapsedTime = (currentTime - previousTime) / 1000; // Divide by 1000 to get seconds
  Wire.write(0x43); // Gyro data first register address 0x43
  Wire.requestFrom(MPU, 6, true); // Read 4 registers total, each axis value is stored in 2 registers
  GyroX = (Wire.read() << 8 | Wire.read()) / 131.0; // For a 250deg/s range we have to divide first the raw value by 131.0, according to the datasheet
  GyroY = (Wire.read() << 8 | Wire.read()) / 131.0;
  GyroZ = (Wire.read() << 8 | Wire.read()) / 131.0;
  // Correct the outputs with the calculated error values
  GyroX = GyroX + 0.56; // GyroErrorX ~(-0.56)
  GyroY = GyroY - 2; // GyroErrorY ~(2)
  GyroZ = GyroZ + 0.79; // GyroErrorZ ~ (-0.8)
  // Currently the raw values are in degrees per seconds, deg/s, so we need to multiply by second (s) to get the angle in degrees
  gyroAngleX = gyroAngleX + GyroX * elapsedTime; // deg/s * s = deg
  gyroAngleY = gyroAngleY + GyroY * elapsedTime;
  yaw =  yaw + GyroZ * elapsedTime;
  // Complementary filter - combine accelerometer and gyro angle values
  roll = 0.96 * gyroAngleX + 0.04 * accAngleX;
  pitch = 0.96 * gyroAngleY + 0.04 * accAngleY;
  // Print the values on the serial monitor
  Serial.print(roll);
  Serial.print(",");
  Serial.print(pitch);
  Serial.print(",");
  Serial.println(yaw);
void calculate_IMU_error() {
  // We can call this function in the setup section to calculate the accelerometer and gyro data error. From here we will get the error values used in the above equations printed on the Serial Monitor.
  // Note that we should place the IMU flat in order to get the proper values, so that we then can the correct values
  // Read accelerometer values 200 times
  while (c < 200) {
    Wire.write(0x3B);
    AccX = (Wire.read() << 8 | Wire.read()) / 16384.0 ;
    AccY = (Wire.read() << 8 | Wire.read()) / 16384.0 ;
    AccZ = (Wire.read() << 8 | Wire.read()) / 16384.0 ;
    // Sum all readings
    AccErrorX = AccErrorX + ((atan((AccY) / sqrt(pow((AccX), 2) + pow((AccZ), 2))) * 180 / PI));
    AccErrorY = AccErrorY + ((atan(-1 * (AccX) / sqrt(pow((AccY), 2) + pow((AccZ), 2))) * 180 / PI));
    c++;
  //Divide the sum by 200 to get the error value
  AccErrorX = AccErrorX / 200;
  AccErrorY = AccErrorY / 200;
  c = 0;
  // Read gyro values 200 times
  while (c < 200) {
    Wire.write(0x43);
    GyroX = Wire.read() << 8 | Wire.read();
    GyroY = Wire.read() << 8 | Wire.read();
    GyroZ = Wire.read() << 8 | Wire.read();
    // Sum all readings
    GyroErrorX = GyroErrorX + (GyroX / 131.0);
    GyroErrorY = GyroErrorY + (GyroY / 131.0);
    GyroErrorZ = GyroErrorZ + (GyroZ / 131.0);
    c++;
  GyroErrorX = GyroErrorX / 200;
  GyroErrorY = GyroErrorY / 200;
  GyroErrorZ = GyroErrorZ / 200;
  // Print the error values on the Serial Monitor
  Serial.print("AccErrorX: ");
  Serial.println(AccErrorX);
  Serial.print("AccErrorY: ");
  Serial.println(AccErrorY);
  Serial.print("GyroErrorX: ");
  Serial.println(GyroErrorX);
  Serial.print("GyroErrorY: ");
  Serial.println(GyroErrorY);
  Serial.print("GyroErrorZ: ");
  Serial.println(GyroErrorZ);
I believe you should be using the WiFiNINA library - not WiFi.h
WiFiNINA - Arduino Reference
Your code is nicely commented—great job!
If I understand your question correctly, you’re saying the device never connects to the network. Here are some things to consider:
  1. Network Connectivity:
  • Do you have another device that connects to the same network and on the same band (2.4 GHz or 5 GHz)?
  • If so, does it work in the same location as your project? Dead spots in WiFi coverage can cause connectivity issues and can be frustrating to troubleshoot.
  1. Setup Issues:
  • Your setup looks fine at first glance, but double-check your SSID (network name) and password to ensure there are no typos or mismatches. Even a small mistake can prevent connection.
  1. Test with Another Board:
  • If possible, test with another board to see if it can connect to the network. This will help you determine whether the issue is with the board, code, or network setup.
If none of these solutions help, try simplifying your environment to eliminate potential variables (e.g., move closer to the router or test with a different access point). Let us know how it goes!
Thanks! Didn't catch that one
I've checked all these things, and tested with an adafruit board as well. The problem I see is that it shuts itself off before it can even connect to the wifi.
Can you post the following:
A. Annotated Schematic: Clearly show all connections, including power, ground, and power sources. This will help us understand your circuit setup and identify potential issues.
B. Technical Information Links: Provide links to technical documentation for each hardware component in your setup. Avoid links to sales sites like Amazon, as they often lack the detailed specifications we need to assist you effectively.
Why Do We Want This:
We can’t accurately assist without knowing the specifics of your setup. Clear, detailed descriptions will allow us to offer the best help possible. Without this information, diagnosing and solving your issues will be much harder.
Sounds like the power supply is inadequate.
