Board Not Recognised by Computer/IDE
Hello, I am facing an issue in that the board is not recognized by the computer. Can you have any solution or any suggestion to solve it? Thanks.
I found the solution on this website: Click Here to Visit
Welcome to the Forum! Read the forum guidelines to see how to properly ask a question and some good information on making a good post. Please describe what the hardware do you use.
Your post is lacking details. Among those that might help us to help you
  1. Which board?
  2. Is the board a clone or an genuine Arduino?
  3. Which IDE (2.0.x or ...)?
  4. Which operating system?
  5. Did it ever work before?
  6. If it worked before, what is the project that you were working on when it started to fail?
Alwasy follow what @b707 & @sterretje suggested when posting.
Generally, install IDE 2.0 and make sure that you install all the package cores and libraries that pop up after the IDE installation. Then use a good data USB cable to connect your board to to the computer, the IDE should auto-detect your board.
If it does not, you can manually install your board's Package Core.
For ESP boards, follow these guides ESP32 with Arduino IDE 2.0/ESP82 with Arduino IDE 2.0
Also try a different USB cable, there are cables that are intended for charging devices, those only have the power and ground wires and leave out the two data wires entirely.
