Board Resets but seems to continue from where it left off
Hi all,
I am running into a problem I cannot seem to fix with other forums and debugging. My partner and I are designing a point picking and plasma cutting robot for our senior project and have had a "slight" issue with our code for our linear actuator
#include <ArduinoSTL.h>
#include <AccelStepper.h>
#include <cmath>
#include <MultiStepper.h>
//outputs
// Global ints
volatile int counterbase = 0;
volatile int counterarm = 0;
bool math = true;
bool zero = false;
bool firstpoint = false;
float radians = 0.00104666; // multiplier to get steps to radians
float res = 0.1;
// Vectors for math
std::vector<float> xpoint;
std::vector<float> ypoint;
std::vector<int> angles;
std::vector<int> anglestwo;
// steppers
int baseStepPin = 22;
int baseDirPin = 23;
int armStepPin = 24;
int armDirPin = 25;
AccelStepper baseStepper(AccelStepper::DRIVER, baseStepPin, baseDirPin);
AccelStepper armStepper(AccelStepper::DRIVER, armStepPin, armDirPin);
float stepsperrev = 2000;
float motorspeed = 100;
float movespeed = 200;
  //pins
  pinMode(5, OUTPUT);
  pinMode(44, OUTPUT);
  pinMode(45, OUTPUT);
  Serial.begin(9600); // Initialize Serial communication
  digitalWrite(51, LOW);
  // Sets pins as interrupt
  pinMode(2, INPUT_PULLUP);
  pinMode(3, INPUT_PULLUP);
  pinMode(18, INPUT_PULLUP);
  pinMode(19, INPUT_PULLUP);
  // Sets which functions run at interrupt
  attachInterrupt(0, ai0, RISING);
  attachInterrupt(1, ai1, RISING);
  attachInterrupt(4, ai2, RISING);
  attachInterrupt(5, ai3, RISING);
  baseStepper.setMaxSpeed(movespeed);
  baseStepper.setAcceleration(1000);
  armStepper.setMaxSpeed(movespeed);
  armStepper.setAcceleration(1000);
  digitalWrite(5, LOW);
    while (analogRead(A10) < 1015) {// both while loops set arms to zero
    baseStepper.setSpeed(-motorspeed);
    baseStepper.runSpeed();
  Serial.println("base zero'd");
    while (analogRead(A12) < 1015) {
    armStepper.setSpeed(motorspeed);
    armStepper.runSpeed();
  Serial.println("arm zero'd");
  digitalWrite(5, HIGH);
  baseStepper.setCurrentPosition(0);
  armStepper.setCurrentPosition(0);
  counterbase = counterarm = 0;
  digitalWrite(45, HIGH);
  delay(4000);
  digitalWrite(45, LOW);
  // Button checks at the start of the loop each time
  int buttontwo = analogRead(A3);
  int buttonthree = analogRead(A6);
  int buttonfour = analogRead(A8);
 Serial.println("looping");
  if (buttontwo > 1015) { // Add the x and y positions to the vectors
    xpoint.push_back(((cos(M_PI - (counterbase * radians))) * 18) +
                      (cos((M_PI - (counterbase * radians) - (counterarm * radians)))) * 18); // add to xvector
    ypoint.push_back(sin(M_PI - (counterbase * radians)) * 18 +
                      sin((M_PI - (counterbase * radians) - (counterarm * radians))) * 18); // add to yvector
        // Print the contents of the vectors
        Serial.println("X Positions:");
        for (size_t i = 0; i < xpoint.size(); ++i) {
            Serial.print(xpoint[i]);
            Serial.print(", ");
        Serial.println("Y Positions:");
        for (size_t i = 0; i < ypoint.size(); ++i) {
            Serial.print(ypoint[i]);
            Serial.print(", ");
  if (buttonthree > 1015 && math) { // interpolate the point between the x and y values based on which is farther
    for (int i = 1; i < xpoint.size(); ++i) {
      float x = (xpoint.at(i) - xpoint.at(i - 1));
      float y = (ypoint.at(i) - ypoint.at(i - 1));
      float rx = std::abs(x) / res;
      float ry = std::abs(y) / res;
      if (std::abs(x) >= std::abs(y)) {
        for (int g = 0; g <= rx; ++g) {
          float x1 = (xpoint.at(i - 1) + (res * x / std::abs(x) * g));
          float y1 = (ypoint.at(i - 1) + ((y / rx) * g));
          float H = sqrt(pow(x1, 2) + pow(y1, 2));
          angles.push_back((180-((acos(x1 / H) + acos((pow(18, 2) + pow(H, 2) - pow(18, 2)) / (2 * 18 * H))) * (180 / M_PI)))* (stepsperrev / 360)* 3);
          anglestwo.push_back((180-(acos((pow(18, 2) + pow(18, 2) - pow(H, 2)) / (2 * 18 * 18)) * (180 / M_PI))) * (stepsperrev / 360)* 3* -1);
        for (int g = 0; g <= ry; ++g) {
          float x1 = (xpoint.at(i - 1) + ((x / ry) * g));
          float y1 = (ypoint.at(i - 1) + (res * y / std::abs(y) * g));
    math = false;
    Serial.println("math done");
      Serial.println(angles.size());
    Serial.println("Encoder vector elements: ");  // Print vector for testing
    for (int i = 0; i < angles.size(); ++i) {
      Serial.print(angles[i]);
      Serial.print(", .");
      Serial.print(anglestwo[i]);
      Serial.println(" ");
  zero = true;
  Serial.println("zero'd");
  if (buttonfour > 1015 && zero == true) {
    Serial.println("motor move");
    for (int i = 0; i < 1; ++i) {
      // Move the motors listed position
      baseStepper.moveTo(angles[i]);
      armStepper.moveTo(anglestwo[i]);
      Serial.println("motor moving");
      // Wait until both steppers reach their target position
      while (baseStepper.distanceToGo() != 0 || armStepper.distanceToGo() != 0) {
        baseStepper.run();
        armStepper.run();
    digitalWrite(44, HIGH);
    digitalWrite(44, LOW);
    firstpoint = true;
  if (buttonfour > 1015 && firstpoint == true) {
      for (int i = 1; i < angles.size() && i < anglestwo.size(); ++i) {
        baseStepper.run();
        armStepper.run();
      // Delay between moves
      delay(10);
  if (buttonfour > 1015) {
      Serial.print(" ");
  delay(200);
void ai0() {  // Encoder one one interrupt
  if (digitalRead(3) == LOW) {
    counterarm++;
    counterarm--;
void ai1() {  // Encoder one two interrupt
  if (digitalRead(2) == LOW) {
    counterarm--;
    counterarm++;
void ai2() {  // Encoder two one interrupt
  if (digitalRead(18) == LOW) {
    counterbase++;
    counterbase--;
void ai3() {  // Encoder two two interrupt
  if (digitalRead(19) == LOW) {
    counterbase--;
    counterbase++;
The issue arises around line 197 when the actuator on the end of the arm is commanded to lower and stop. it does, and if i have a print statement saying end moved directly after setting pin 44 to low(controlling a relay) but then it resets the code back to the set up, I know this because it redoes the print statements "base zeroed" and "Arm zeroed" but then it rockets back to the second point in the list. The program runs fine with everything wired and without that little section of code (lines 197 to 200). max draw on the 5 volt pin at the time of reset is only 5mA plus whatever the board is using.
Any help is greatly appreciated.
Which Arduino and how is it powered?
Mega 2560 and a usb port, the actuator and motors are powered by a 24V power supply relays for the actuator and the steppers have pulsed drivers
Do you have all your grounds tied together (Mega 2560 + power supply)? Sounds like you are having a power dip/spike that is resetting your board.
Nowhere in this sketch does it print these exactly like this. Is there a chance that you're running an earlier or alternate version of your code?
The line in setup() reads Serial.println("base zero'd"); and Serial.println("arm zero'd");.
This is probably not the issue but who knows? Just thought I'd mention it.
I always like to Serial.println(F("code name version x")); right after Serial.begin(9600);.
We went to our schools electronics department and the assistant professor recommended tying grounds together. Works perfectly now. You're a little late on the reply, but we definitely appreciate the input. Sorry, were mechanical engineers not electrical......
I wonder if it has something to do with
//etc
    firstpoint = true;
then right after
//etc
then
What I mean is, when zero == true, it stays true since the only time it is false is in your global variable declaration.
Then, with button still pressed (is it or is it still released?), after setting firstpoint to true, with zero still true, won't it just redo the last action that zero == true caused? Once the button state is no longer > 1015, it doesn't look for whether the bools are true or not, so you'd either get the third time the buttonfour > 1015, which prints encoder vector elements, or the one where zero is true, wouldn't you?
Why not just look for whether buttonfour > 1015 once, and inside that conditional, drive the states of zero and firstpoint being true in a switch/case state machine? You can leave zero being false and firstpoint also being false as empty, and maybe toggle zero back to drive the firstpoint actions, if I'm understanding your program flow correctly.
