Hi there,
I am trying to do a DIY robot fish for work, from this website: http://www.open-electronics.org/robofish-create-your-robot-fish-with-arduino/ (the website has the code for the fish too). I have an arduino nano, two IR sensors, magnet switch, 4 AA batteries with holders and three servo motors. The whole circuit has power, sensors are running fine, too, but whenever the board is turned on or reset the 3 servos turn a few quick notches and stop.
The DIY fish had an Uno and digital servos. Problem is, I accidentally ordered analog servos (fitec fs90 micro servo 4.8V, http://www.robotshop.com/ca/en/9g-micro-servo-motor-4-8v.html?gclid=CIi87bTG1c4CFQaJaQodNvUCzA).
I tried switching the signal pins in the code and on the board to analog pins, no luck. I tried to attach the signal wires to digital pins with PWM (pins 5, 6, and 9) and use analogWrite() in place of the Write() command in the code and I get “‘class Servo’ has no member named ‘analogWrite’”.
Can someone please tell me what I’m doing wrong? I would greatly appreciate it.
Thank you so much!
This is the code with the changes I made, the original is on the link for the DIY fish at the top
// ROBOFISH
// di Segatello Mirco
#include <Servo.h>
Servo Servo1, Servo2, Servo3; // create servo object to control a servo
int i, time, obstacle;
int pos1, pos2, pos3;
int pos1R, pos2R, pos3R;
int phase=45;
int velocity=2000;
int maxDeflexion=20;
int maxDefobs=20;
int actualTime;
float shift;
const int center1=98;
const int center2=90;
const int center3=105;
const int sens_SX=7;
const int sens_DX=8;
const int lostTime=3000;
Servo1.attach(5);
Servo2.attach(6);
Servo3.attach(9);
pinMode(sens_SX, INPUT);
pinMode(sens_DX, INPUT);
pinMode(13, OUTPUT);
time=velocity/360;
shift=0;
for (i=0; i<360; i++) {
pos1 = i+2*phase;
pos2 = i+phase;
pos3 = i;
if (pos1>359) pos1-=360;
if (pos2>359) pos2-=360;
if (pos3>359) pos3-=360;
if (pos1>179) pos1=360-pos1;
if (pos2>179) pos2=360-pos2;
if (pos3>179) pos3=360-pos3;
pos1R=map(pos1,0,180,center1-maxDeflexion-obstacle,center1+maxDeflexion-obstacle);
pos2R=map(pos2,0,180,center2-maxDeflexion-obstacle,center2+maxDeflexion-obstacle);
pos3R=map(pos3,0,180,center3-maxDeflexion-obstacle,center3+maxDeflexion-obstacle);
Servo1.analogWrite(pos1R);
Servo2.analogWrite(pos2R);
Servo3.analogWrite(pos3R);
delay(time);
obstacle=int(shift);
if (digitalRead(sens_DX)==0) {
if (obstacle<maxDefobs) shift=shift+0.05;
actualTime=millis();
if (digitalRead(sens_SX)==0) {
if (obstacle > (-maxDefobs)) shift=shift-0.05;
if (digitalRead(sens_SX)==1 && digitalRead(sens_SX)==1 && obstacle!=0)
if (millis()>actualTime+lostTime) {
if (shift>0) shift=shift-0.05;
if (shift<0) shift=shift+0.05;
