i recently purchased Mega board with ESP8266 and tried to upload the sketch. My board manager was Arduino Mega (or) Mega 2560.
When i upload the sketch -> the code compiles and in the final seconds of upload i get the following error message. I tried hitting reset button -> but it does not work. Any suggestion?
i was able to execute this code in standalone Mega 2560. My objective was to send data to WiFi and that is were i procured the Mega 2560 board with Esp.
You answered neither of my questions. It is more difficult to help you if it is a one way conversation.
You posted code improperly. Did you not see a warning? Read the forum guidelines to see how to properly post code and some good information on making a good post.
Use the IDE autoformat tool (ctrl-t or Tools, Auto format) before posting code in code tags.
You can go back and fix your original post by highlighting the code and clicking the </> in the menu bar.
i am new the Mega 2560 + ESp8266 topic. I am not aware of the DIP switches. Is this a setting which i have to do? if yes, kindly share me some instructions.
I did upload a code which is successfully uploaded into Mega 2560 but get time out issues when i upload with the ESP8266 variant.
My objective is to run Mega 2560 sketch with the feature of ESP8266 webserver.
#include "lin_frame.h"
#define BUFF_SIZE 64
#define FRAME_BYTE 0x00
#define SYNC_BYTE 0x55
#define WHEEL_SLAVE1 97
#define WHEEL_SLAVE2 240
#define LIN_BUFF_SIZE 16
const uint8_t pinTX2 = 16;
const uint8_t pinRX1 = 19;
const uint8_t pinTX1 = 18;
const uint8_t pinCS = 8;
const uint8_t pinTXE = 13;
int i =0;
LinFrame frame;
const uint8_t
//grLINPacket[] = { 0xF0, 0xFD, 0xD0, 0x00, 0x34, 0x00 }; //bad checksum
grLINPacket[] = {0xC1, 0xFF, 0x0B, 0x57, 0x44, 0x51, 0xFF, 0x03, 0x90, 0xB2 }; //good msg
//give the serial ports names to make things more human-readable
HardwareSerial
*VehicleSimulator = (HardwareSerial *)&Serial2,
*SerialConsole = (HardwareSerial *)&Serial;
enum eLINStates
SEEK_FRAME_START = 0,
SEEK_SYNC_BYTE,
RECEIVE_FRAME_DATA,
volatile uint8_t
rxHeadPtr = 0;
volatile uint16_t
gruRxBuffer[BUFF_SIZE];
uint8_t
rxTailPtr = 0;
void setup( void )
//UART0 (default) serial console
SerialConsole->begin(19200);
pinMode( pinCS, OUTPUT );
digitalWrite( pinCS, HIGH );
pinMode( pinTXE, OUTPUT );
digitalWrite( pinTXE, HIGH );
//UART2 used to simulate LIN messages; connect TX2 to RX1 for bench testing
pinMode( pinTX2, OUTPUT );
VehicleSimulator->begin(19200);
//UART1 to be our LIN receiver
UCSR1C = _BV(UCSZ11) | _BV(UCSZ10); //async operation, 8N1
UBRR1 = 51; //19.2kbaud UBRR = (16MHz / 16 x 19200) - 1
UCSR1B = _BV(RXCIE1) | _BV(RXEN1) | _BV(TXEN1); //enable the UART1 receiver & transmitter and UART1 RX interrupt
pinMode( pinRX1, INPUT_PULLUP ); //should be input out of reset; shown for clarity
pinMode( pinTX1, OUTPUT );
SerialConsole->println( "Starting..." );
}//setup
void loop( void )
static uint32_t
tLIN = 0ul;
uint32_t
tNow = millis();
// SerialConsole->println(tNow );
// SerialConsole->println(tLIN );
//#if 0
//send a test message once a second
if( (tNow - tLIN) >= 1000ul )
SerialConsole->println( "Print debug..."+i );
i=i+1;
tLIN = tNow;
//send a break on UART0 by disabling TX, setting the pin
//low and waiting >10 bit times at 19200
UCSR2B &= ~(_BV(TXEN2)); //disable transmitter to access pin
digitalWrite( pinTX2, LOW ); //drive pin low
delayMicroseconds( 1000ul ); //wait >>10x bit times at 19200
digitalWrite( pinTX2, HIGH ); //set pin high
UCSR2B |= _BV(TXEN2); //re-enable transmitter
delayMicroseconds( 50ul ); //wait for pin to rise and settle
//send the sync character
VehicleSimulator->write( SYNC_BYTE );
//send the data
VehicleSimulator->write( grLINPacket, sizeof( grLINPacket ) );
}//if
//#endif
//process LIN messages
linRXStateMachine();
delay(100);
}//loop
void linRXStateMachine( void )
static uint8_t
stateLIN = SEEK_FRAME_START; //LIN state variable
uint16_t
rx; //combo of status and received byte
uint8_t
b, //rx'd byte
s, //status
tempHead; //temporary receive buffer head pointer value
//read the head pointer
noInterrupts();
tempHead = rxHeadPtr;
interrupts();
//if not the same as the tail pointer there are bytes to process
if( tempHead != rxTailPtr )
do
//read the combination status and rx'd byte from the buffer
rx = gruRxBuffer[rxTailPtr];
//split into the byte and status
b = (uint8_t)(rx & 0xff);
s = (uint8_t)((rx >> 8) & 0xff);
switch( stateLIN )
case SEEK_FRAME_START:
//waiting for a break indication (framing error; FE1 bit in status register)
//start of frame == framing error and rx'd a 0x00
if( (s & _BV(FE1)) && (b == FRAME_BYTE) )
stateLIN = SEEK_SYNC_BYTE;
case SEEK_SYNC_BYTE:
//byte immediately following the start condition should be a SYNC byte
if( b == SYNC_BYTE )
//got it; reset the LIN frame
frame.reset();
//and go get the frame
stateLIN = RECEIVE_FRAME_DATA;
}//if
case RECEIVE_FRAME_DATA:
//if we don't see a framing error
if( !(s & _BV(FE1) ) )
//just append the received byte to the frame
frame.append_byte( b );
}//if
//we see a break here; if we rx'd a 0x00 we
//are looking at the start of the next frame so we can process
//the one sitting in the buffer
if( b == 0x00 )
//if the frame is valid... frame.isValid()
if(true )
//show it
DumpFrame();
}//if
//frame check failed
SerialConsole->println( "Message invalid" );
}//else
//got back and wait for the sync byte
}//if
//got a framing error but not an accompanying 0x00
//go to seek a frame start state
}//else
}//else
}//switch
//after each pass, advance the tail pointer...
rxTailPtr = (rxTailPtr + 1) & (BUFF_SIZE - 1);
//until we match the head pointer when we started this
}while( rxTailPtr != tempHead );
}//if
}//linRXStateMachine
ISR( USART1_RX_vect )
uint8_t
ch,
s;
//read the character and the status register
s = UCSR1A; //need to be in this order (read status then received data) to get the right status value
ch = UDR1;
//put the status byte in the most-sig. byte and the character in the least-sig byte of the word in the buffer
gruRxBuffer[rxHeadPtr] = (uint16_t)((s << 8) | ch);
//bump the head pointer
rxHeadPtr = (rxHeadPtr + 1) & (BUFF_SIZE - 1);
}//RX interrupt
void DumpFrame( void )
if (frame.get_byte(0) != WHEEL_SLAVE2)
return;
for (uint8_t idx = 0; idx<frame.num_bytes(); idx++)
uint8_t b = frame.get_byte(idx);
if( b <= 0xf )
SerialConsole->write( '0' );
SerialConsole->print( b, HEX );
SerialConsole->write( ' ' );
}//for
SerialConsole->println();
}//DumpFrame
