Im looking for a board that can handle upto 4 simultaneous digital audio inputs from mems microphones for an audio application. From what i understand the standard I2S channel only allows for 2 audio inputs at once
so im assuming i would require 2x the amount of i2s on the board.
are there any boards i can buy to use for this type of work ?
Robin2:
I intended to exclude "normal fidelity" as well. An Arduino is only capable of really crap sound on a single channel.
...R
thats a bummer haha, what about interfacing it to a phone so to send the 4 independent microphone signals to the phone for conversion/ replacing the internal microphone for other applications either through type c/microusb. Or would something like that require a special evaluation board ?
kekocatsnin:
I have no idea.
You need to ask on a Forum that specializes in audio stuff. This Forum is for Arduino projects.
"An Arduino is only capable of really crap sound on a single channel.An Arduino is only capable of really crap sound on a single channel."
Not true, you can digitize 16-bit single channel mono audio at 44.1KHz and store to SD card with a 16 MHz Arduino.
Take a looke here: http://forum.arduino.cc/index.php?topic=180769.0
You need an external SPI ADC and it will use all the capacity of the Arduino.
The other request, 4 channels at once: you can sample 4 channels simultaneously with the proper ADC, but you are still limited internally by the uC's databus to moving the data from any one channel at a time. A fast enough processor will let you move all 4 channels in the same time period to appear as if all were being done at the same time.
