Boards LED on pin 13 Flashes continously
When I plug my Arduino Uno into the usb port on my computer, the built in LED on the board flashes. This is before I start my Arduino software. It will continue after I press the reset button.
When I run the very basic blink sketch, there are two other built in LEDs on the Uno that also flash, but then go out.
I am running the Arduino software on a computer running Window XP Service pack 3.
Any suggestions?
Sounds like normal operation to me? The bootloader on the controller chip uses/manages pin13 led until it passes control over to a uploaded sketch, then the sketch controls what you do with pin13 led.
Lefty
Thanks Lefty. I had a lot of problems just getting the computer I am using to load the software. When I first got my Uno, I had a dedicated laptop for it. I was scanning for viruses, malware, etc one day when the mother board burnt out. The Uno software and hardware worked great on it. Right now I have my Uno plugged into my new laptop running windows 8, and the led on pin 13 is flashing. Thank you for clarifying this
gusofmerced:
The Arduino board will run whatever program it has regardless of what you are doing on your PC.
gusofmerced:
That starts the previously loaded program over, not erases the memory.
gusofmerced:
I'm going to guess they say "TX" and "RX" next to them... probably a hint to why they flash.
James C.
Yes you were right about the tx and rx leds. Any idea about what would happen if I burned my bootloader? I saw that when I was on my tools menu.
gusofmerced:
If you have a hardware programmer attached (which is listed in the Programmer part of the menu), then the bootloader will be re-programmed. Otherwise, nothing will happen.
(deleted)
Thanks spycatcher2k. I modified a the blink program to set pin 13 low and go into a loop. now it stays out. I will do what you do. Thanks for the tip
