boards.txt and adding a new option to the file
When selecting a board in the Arduino IDE there is a preselected choice based on the contents of the boards.txt file in the Arduino hardware folder.
There is amongst others a “Arduino Pro or Pro Mini” choice possible.
When selecting that one there is a subset for processor type: Atmega328 or Atmega 168 and 5V(16MHz) or 3.3V(8MHz).
When I edit the board.txt file to get a Atmega168 3.3V(2MHz) and Atmega328 3.3V(2MHz) these boards duly appear, but now the 3.3V(8Mhz) versions have disappeared.
How can I obtain a choice of 6 Pro Mini processor versions (328 and 168 3.3V but then both 2MHz and 8MHz, plus the two 5V versions), instead of being limited to just 4?
Here is the boards.txt portion I use for the Pro Mini: there are 5 versions in this text, but the 3.3V 8MHz version refuses to appear in my menu.
pro.name=Arduino Pro or Pro Mini
pro.upload.tool=avrdude
pro.upload.protocol=arduino
pro.bootloader.tool=avrdude
pro.bootloader.unlock_bits=0x3F
pro.bootloader.lock_bits=0x0F
pro.build.board=AVR_PRO
pro.build.core=arduino
pro.build.variant=eightanaloginputs
## Arduino Pro or Pro Mini (5V, 16 MHz) w/ ATmega328
pro.menu.cpu.16MHzatmega328=ATmega328 (5V, 16 MHz)
pro.menu.cpu.16MHzatmega328.upload.maximum_size=30720
pro.menu.cpu.16MHzatmega328.upload.maximum_data_size=2048
pro.menu.cpu.16MHzatmega328.upload.speed=57600
pro.menu.cpu.16MHzatmega328.bootloader.low_fuses=0xFF
pro.menu.cpu.16MHzatmega328.bootloader.high_fuses=0xDA
pro.menu.cpu.16MHzatmega328.bootloader.extended_fuses=0x05
pro.menu.cpu.16MHzatmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328.hex
pro.menu.cpu.16MHzatmega328.build.mcu=atmega328p
pro.menu.cpu.16MHzatmega328.build.f_cpu=16000000L
## Arduino Pro or Pro Mini (3.3V, 2 MHz) w/ ATmega328
pro.menu.cpu.8MHzatmega328=ATmega328 (3.3V, 2 MHz)
pro.menu.cpu.8MHzatmega328.upload.maximum_size=30720
pro.menu.cpu.8MHzatmega328.upload.maximum_data_size=2048
pro.menu.cpu.8MHzatmega328.upload.speed=9600
pro.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xFF
pro.menu.cpu.8MHzatmega328.bootloader.high_fuses=0xDA
pro.menu.cpu.8MHzatmega328.bootloader.extended_fuses=0x05
pro.menu.cpu.8MHzatmega328.bootloader.file=atmega/ATmegaBOOT_168_atmega328_pro_8MHz.hex
pro.menu.cpu.8MHzatmega328.build.mcu=atmega328p
pro.menu.cpu.8MHzatmega328.build.f_cpu=2000000L
## Arduino Pro or Pro Mini (3.3V, 8MHz Int) w/ ATmega328
pro.menu.cpu.8MHzatmega328=ATmega328 (3.3V, 8MHz Int)
pro.menu.cpu.8MHzatmega328.bootloader.low_fuses=0xD2
pro.menu.cpu.8MHzatmega328.build.f_cpu=8000000L
## Arduino Pro or Pro Mini (5V, 16 MHz) w/ ATmega168P
pro.menu.cpu.16MHzatmega168=ATmega168P (5V, 16 MHz)
pro.menu.cpu.16MHzatmega168.upload.maximum_size=14336
pro.menu.cpu.16MHzatmega168.upload.maximum_data_size=1024
pro.menu.cpu.16MHzatmega168.upload.speed=19200
pro.menu.cpu.16MHzatmega168.bootloader.low_fuses=0xff
pro.menu.cpu.16MHzatmega168.bootloader.high_fuses=0xdd
pro.menu.cpu.16MHzatmega168.bootloader.extended_fuses=0x00
pro.menu.cpu.16MHzatmega168.bootloader.file=atmega/ATmegaBOOT_168_diecimila.hex
pro.menu.cpu.16MHzatmega168.build.mcu=atmega168P
pro.menu.cpu.16MHzatmega168.build.f_cpu=16000000L
## Arduino Pro or Pro Mini (3.3V, 2 MHz) w/ ATmega168P
pro.menu.cpu.8MHzatmega168=ATmega168P (3.3V, 2 MHz)
pro.menu.cpu.8MHzatmega168.upload.maximum_size=14336
pro.menu.cpu.8MHzatmega168.upload.maximum_data_size=1024
pro.menu.cpu.8MHzatmega168.upload.speed=9600
pro.menu.cpu.8MHzatmega168.bootloader.low_fuses=0xc6
pro.menu.cpu.8MHzatmega168.bootloader.high_fuses=0xdd
pro.menu.cpu.8MHzatmega168.bootloader.extended_fuses=0x00
pro.menu.cpu.8MHzatmega168.bootloader.file=atmega/ATmegaBOOT_168_pro_8MHz.hex
pro.menu.cpu.8MHzatmega168.build.mcu=atmega168P
pro.menu.cpu.8MHzatmega168.build.f_cpu=2000000L
We've already been over this. You need to use a unique menu ID for each option. You are using 8MHzatmega328 for both the ATmega328 (3.3V, 2 MHz) and ATmega328 (3.3V, 8MHz Int) options, thus the issue you're seeing. I'm guessing you have the same issue with the ATmega168 but I don't see the boards.txt entry for ATmega168P (3.3V, 8 MHz) so maybe it's just missing entirely.
For more information see:
Not only can you have more than 4 options in a menu, you can have more than one submenu. Check out all the options in my Standalone Chip menu to see what can be done.
mrd.zip (5.21 KB)
pert:
Arduino IDE 1.5 3rd party Hardware specification · arduino/Arduino Wiki · GitHub
I guess you refer to http://forum.arduino.cc/index.php?topic=455407.msg3132326#msg3132326?
You are right, I am sorry, I did overlook it yesterday when looking up previous posts and at the time of writing in this thread last week I had overlooked that one link.
Now I understand!
Thank you,
Erik
Jiggy-Ninja:
Thanks for your reply! Downloaded, printed out, and now studying your work..
