Boat Motor Control
Im working on a project to Electrify the boat motor controls on my boat its a small trailer sailer. It has an outboard motor on the back . The boat has fairly tall sides and Its really difficult to keep a view on where you're going while your trying to reach outside the cockpit behind you to change the gear position . The throttle control is a tiller type that you twist . It too is hard to keep in your hands while holding and steering mostly with the sailboats rudder . I Have most of the mechanical aspects figured out and I'm not sure if I will need a small magnetic reed switch to serve as an "In Neutral Sensor" so far the Stepper motor controlling the gearbox on the Outboard is only doing moderately well keeping up with the Optical rotary encoder. The program is a little more complex because I Decided I want one lever that you push forward (connected to the Optical rotary Encoder) to proceed forward in gear with the boat and the same lever that you pull all the way back to proceed in reverse . To accomplish this the program has to take that rotary encoder info and real time it to both the stepper and the Servo. Reversing it and scaling it to open the throttle with the servo after the boat has been shifted into forward or reverse by the stepper . I have finished writing the code and am now looking for any clever Ideas to improve it. The biggest disappointment that I'd like to somehow fix is The Issue of lost steps from moving the encoder too fast for the Arduino Uno. My Sketch has 2 Parts: a Main Program and a Diagnostic Mode.. I upload to the Arduino changing Diagnostic mode to a 1 or a Zero to use the controls or see serial data in order to assist in troubleshooting the code .. Diagnostic mode doesn't work very well but It's helpful to a very small degree. I'd love to hear from any one who might have Ideas for improving this sketch in such a way as to true up the step count at each practical spot in the program . I have it set up so that the rotary encoder counter resets to 0 when close to Neutral so that there is a rather large dead band at the Neutral position. This seems to help with the issue but only a little . after 4 or 5 times from forward to reverse and back to Neutral . Neutral always comes up in a different spot, maybe that's as good as it gets but being a Novice I had to ask if there is an Idea I'm overlooking so I don't have to add the complexity of a Neutral indicator to the motor . Anyway here is the code I apologize in advance
#include <AccelStepper.h>
#include <Servo.h>
Servo throttleServo;  // create servo object to control a throttleServo
#define motorInterfaceType 1
#define startIndicator 3 //on stepper driver
#define servoPin 4 // on spare stepper driver
#define stepperMove 2//this was 5 and is now 2 for cnc uno
#define outputA 6 // output of the rotry encoder input of the ardrino lower left of stepper driver
#define outputB 7// output of the rotry encoder input of the ardrino lower left of stepper driver
#define outputC 1// this will be a momentary switch when pressed will zero the counter maby
#define stepperEnable 8// labled on shield
#define stepperDirecton 5//; juat changed from 9 for uno cnc shield
int currentStateA;
AccelStepper ForwardReverseStepper(motorInterfaceType, stepperMove, stepperDirecton);
int   counter;
int lastStateA;
int controlMultiplier =1; ;//various spots throuout program. The  counter will be amplified
                    //to result in less or more control travel for same control movment
                    // so far counter Multipliers are F,R,FN,RN
int   F = 4;
int   R = 4;
int   FN = 3.4;
int   RN = 3.4;
int  diagnosticMode =0;// change to 1 to enter diagnostic test mode
// the next 4 lines are map constants
int   X = 500;   // servo throtle in forward "From High" portion of map instruction
int   Y = 4900;  // servo throtle in forward "to High" portion of map instruction
int   Z = 10;  // stepper control between reverse and Nutral also forward and nutral "from high"
int   D = 400; // stepper control between reverse and Nutral also forward and nutral "to thgh"
               // the next 2 lines are the exzact number of steps away from 0 that we want to be in gear
               // so figue out the exzact number of steps to forward
               //to be perfectly in forward from Nutral vise versa from 0 to Reverse
int  expectedCCWCurrentStepperPosision = 1300;
int  expectedCWCurrentStepperPosision =  -1300;
int   A;
int   B;
int   C ;
int programSpot; //used in diagnostic mode only should help
                  //identify what part of program Im in
      // the next line is the highest the servo will travel set to  prevent exceding
      //max throttle in miliseconds
int fullThrottleServoPosision  = 2500;
      // the next line is the lowest  the servo will travel
            //set to  prevent exceding idle throttle in miliseconds
int  IdleRPMhServoPosision  = 1000;
      // The shifter stepper has to be kept below a certin
      //point to not shift past forward gear
      // this next line is a (counter point) it  must be set high
      //enough so that the manual control feel is there
      // however the stepper stops at this point and then procedes
      //to an exzact number of steps that we want for our gear posision in forward
      // "expectedForwardCurrentStepperPosision",IS a stepper (number of steps)
      //it's that secondary number that actually determins that gear
      // posision. If you change this you must first change
      //the other to be just above or below this,and you
      // must convert forom counter to number of steps to change the other
int  highStepperPosision = 90 ;
      // Like above only backwards the next line
      // is the (counter pointer) that the stepper
      //will stop moving under
      // control of the lever
      // and begin to advance to "'or retreat to'" the reverse posision .Furthermore
      // the actual posision is
      //expressed in steps and determind by  "expectedCCWCurrentStepperPosision"
int  LowhstepperPosision = -90;
int  ForwardGearStop = 60;   //   gear shifting the spot at wich you have gone into
      //forward gear or out
      //of forward gear ...
      // Just like above the Reverse gear stop is were we wish to stop controling gears and advance the
      // trottle reverse or stop controling the throtle and change gears depending on how you look at it
int ReverseGearStop = -60;   //   gear shifting the spot at wich you have gone into R gear or out
      //of reverse
int  forwardThrotleStart=49; //This is a counter pointer for the beginning of throtle movment in forward
int  reverseThrottleStart=-49 ; //This is a counter pointer for the beginning of throtle movment in forward
int  startServoPosision = 1000;//Kind of self explanitory its were we want the throtle
      //to be set when we pull on the starter rope.
int  currentStepperPosision = 0;// 1500 microseconds is writen as 1500. Every time the program starts
      // we assume the stepper is in 0 or Nutral center
int  currentServoPosision = IdleRPMhServoPosision;// we will start this at idle
                                               //unless the start swich is closed
int comingOutofNutralTowardsForward = 20;
int comingOutofNutralToReverse = -20;
int forceToNutralLowSpot=-7;
int forceToNutralHighSpot=7;
void(* resetFunc) (void) = 0;
  ForwardReverseStepper.setMaxSpeed(900000);
  ForwardReverseStepper.setAcceleration(900000);
  ForwardReverseStepper.setSpeed(900000);
  ForwardReverseStepper.moveTo(0);
  pinMode(stepperEnable, OUTPUT);
  pinMode(stepperDirecton, OUTPUT);
  pinMode(stepperMove, OUTPUT);
  pinMode(startIndicator, INPUT_PULLUP);
  pinMode(outputA, INPUT);// this is output from the encoder input to the controler
  pinMode(outputB, INPUT);// this is output from the encoder input to the controler
  Serial.begin(1200);
  // Read the initial state of outputA on the rotory encoder and declare
  //it to be identical to to the last state of A
lastStateA = digitalRead(outputA);
if (diagnosticMode != 1  ) {
  theMainprogram();
else{
tests();
void theMainprogram()
currentStateA = digitalRead(outputA);// program started
                                  // Read A again did it change?
if (currentStateA != lastStateA  && currentStateA == 1) {
if (digitalRead(outputB) != currentStateA) {
counter =(counter+controlMultiplier);//    increased from 1 to 2.2 because too many revolutions   currentDir = "CW";
      // Encoder is rotating CW so increment
counter  =(counter-controlMultiplier);//     increased from 1 to 2.2 because too many revolutions
                              //currentDir = "CW";currentDir = "CCW";
  // the servo control for throtle in forward ............. ie rotating  CW Blue 7 White 6
  if (counter > forwardThrotleStart) {
    controlMultiplier =F;
          // next 3 lines are to give the stepper a last chance to
          //get that stepper to the desired gear if
          // it did not make it there due to lost
          //steps ie moving lever too fast!!
          // right now however were all about
          //throtle control for servo in forward
          // and these 3 lines are ancalary
   ForwardReverseStepper.moveTo(expectedCWCurrentStepperPosision);
   while (ForwardReverseStepper.currentPosition() != expectedCWCurrentStepperPosision)
   ForwardReverseStepper.run();
          // previous 3 lines are reason why its inportant to alow for
          //lost steps stepper motor has no closed loop operation
          // it will loose steps its inevatable
          //during a while comand  so proper adjustment of forward gear stop and
          //expectedCWCurrentStepperPosision  is criticaly dependant on one another
          // they need to be close together
    digitalWrite(stepperEnable, HIGH);// disable the shifter stepper .High disables. We
                                        //are now about  to throtle up in forward
    throttleServo.attach(servoPin);  // enable throttle servo attaches the servo on pin servoPin
    //exmap(counter, fromLow, fromHigh, toLow, toHigh)
    A = map(counter, 0 , X, 0, Y);// should amplify the throttle posision a higher
                                             //"to high"moves throtle faster
                                             //might help it stay cought up but the more you
                                             //amplify  the more you amplify the error result from
                                             // lost steps
    B = A - 1 ;       // I thought this was going to be  b = a minus the
                      // reverse gear stop so throttle 0 would be counter zero its not
                      // wkg why ?so just droped in a 0 to make it work
                      // leaving in in case will need.
                      // Next linelimits range of  values
                      //to between Idle rpm and full throtle
    B = constrain(B, IdleRPMhServoPosision , fullThrottleServoPosision);
    currentServoPosision = B; // a declaration
    throttleServo.writeMicroseconds(currentServoPosision);  // moves the servo position according
                                                            //    to the
                                                            //    scaled
  // Servo control for throtle in reverse...................... Encoder is CCW Blue 7 White 6
  if (counter <= reverseThrottleStart) {
    controlMultiplier =R;
    // next 3 lines are a last chance to get that stepper to the desired gear
 ForwardReverseStepper.moveTo(expectedCCWCurrentStepperPosision);// this variable
        //must be set carfully
        // see coments control multiplier
 while (ForwardReverseStepper.currentPosition() != expectedCCWCurrentStepperPosision)
digitalWrite(stepperEnable, HIGH); //disable stepper, High disables we
                                        //are soon to throtle up in reverse
                                 // this  attaches the
                                 //servo on pin servoPin
A = map(counter, 0 , X, 0, -Y);
B = A - 0;// I thought this was going to be  B equal to "a minus
          //reverse gear stop" so throttle 0 would be counter zero seems not matter
        // next linelimits range of  values to between Idle rpm and full throtle
// (Stepper) control between   Forward and  nutral
if ((counter <= ForwardGearStop ) && (counter > comingOutofNutralTowardsForward))  {
controlMultiplier =FN;
digitalWrite(stepperEnable, LOW);// low enables
throttleServo.writeMicroseconds(currentServoPosision); //one last chance to get that
                                                            //throtle servo to the Idle posision
throttleServo.detach();// disable servo
    //   exmap(counter, fromLow, fromHigh, toLow, toHigh)
C = map(counter, 0 , Z, 0, D); //stepper should respond faster as tolow and to high
                                       // get farther appart
    //  next linelimits range of  values to between reverse and Nutral
C = constrain(C, LowhstepperPosision , highStepperPosision); //
digitalWrite(stepperEnable, LOW);// stepper Low Enables we
                                        //are soon to move gears
currentStepperPosision = C;
ForwardReverseStepper.moveTo(currentStepperPosision);
// (Stepper) control between  reverse and  nutral
if ((counter >= ReverseGearStop ) && (counter < comingOutofNutralToReverse))  {
controlMultiplier =RN;
                                                            ///hrotle servo to the Idle posision
C = map(counter, 0 , -Z, 0, -D); //stepper should respond faster as "fromhigh" and "tohigh"
// (Stepper) control between  comingOutofNutralToReverse and 0
if ((counter >= comingOutofNutralToReverse ) && (counter <= forceToNutralLowSpot))
while (ForwardReverseStepper.currentPosition() != 0){
counter = 0;
// (Stepper) control between  0 and comingOutofNutralToForward
if ((counter >= forceToNutralHighSpot ) && (counter <= comingOutofNutralTowardsForward))
counter = 0;
lastStateA = currentStateA;
startCheck;
void startCheck() {
while (digitalRead (startIndicator) == 0){
      throttleServo.attach(servoPin);  // attaches the servo on pin servoPin
      throttleServo.writeMicroseconds(startServoPosision);// in microseconds
    if ((digitalRead (startIndicator) == 1) ) {
          throttleServo.writeMicroseconds(currentServoPosision);// in microseconds
///         The test program
void tests() {
counter =(counter-controlMultiplier);//    increased from 1 to 2.2 because too many revolutions   currentDir = "CW";
  Serial.println("program spot is ");
  Serial.println(programSpot);
    Serial.println(" controlMultiplier");
  Serial.println(controlMultiplier);
  Serial.println("The counter is ");
  Serial.println(counter);
  Serial.println("Stepper posision is ");
  Serial.println(currentStepperPosision);
  Serial.println("servo posision is ");
  Serial.println(currentServoPosision);
  // the servo control for throtle in forward =1 ............. ie rotating  CW Blue 7 White 6
    programSpot = 1;
          // next 3 lines are to give the stepper a last chance to get that stepper to the desired gear if
          // it did not make it there due to lost steps ie moving leSver too fast
 //  ForwardReverseStepper.moveTo(expectedCWCurrentStepperPosision);
 Serial.println(" 1");
   //while (ForwardReverseStepper.currentPosition() != expectedCWCurrentStepperPosision)
 //  ForwardReverseStepper.run();
// previous 3 lines are why its inportant to alow for lost steps stepper motor has no closed loop operation
//during a while comand . This is why  proper adjustment of forward gear stop and
 //   digitalWrite(stepperEnable, HIGH);// disable the shifter stepper .High disables. We
       Serial.println(" 1");                                 //are now  to throtle up in forward
  //  throttleServo.attach(servoPin);  // enable throttle servo attaches the servo on pin servoPin
    B = A - 1 ; // I thought this was going to b = a minus
                      //reverse gear stop so throttle 0 would be counter zero
    Serial.println("1");
   // throttleServo.writeMicroseconds(currentServoPosision);  // moves the servo position according to the scaled
  // Servo control for throtle in reverse= 2...................... Encoder is CCW Blue 7 White 6
  if (counter < reverseThrottleStart) {
    programSpot = 2;
// ForwardReverseStepper.moveTo(expectedCCWCurrentStepperPosision);// this variable must be set carfully
 //while (ForwardReverseStepper.currentPosition() != expectedCCWCurrentStepperPosision)
 Serial.println(" 2");
//digitalWrite(stepperEnable, HIGH); //disable stepper high disables we
//throttleServo.attach(servoPin);  // enable throttle servo attaches the servo on pin servoPin
B = A - 0;// I thought this was going to b equal to a plus
          //reverse gear stop so throttle 0 would be counter zero seems not matter
//throttleServo.writeMicroseconds(currentServoPosision);
// (Stepper) control between   Forward and  nutral=3
programSpot = 3;
//throttleServo.writeMicroseconds(currentServoPosision); //one last chance to get that
    Serial.println(" 3 ");                                                        ///hrotle servo to the Idle posision
//throttleServo.detach();// disable servo
Serial.println(" 3");
C = map(counter, 0 , -Z, 0, -D); //stepper should respond faster as "tolow" and "tohigh"
  //  while (ForwardReverseStepper.currentPosition() != currentStepperPosision)
// (Stepper) control between  reverse and  nutral=4
programSpot = 4;
   Serial.println(" 4 ");                                                         ///hrotle servo to the Idle posision
C = map(counter, 0 , -Z, 0, -D); //stepper should respond faster as "tolow" and "toHigh"
    // ForwardReverseStepper.moveTo(currentStepperPosision);
    Serial.println("4");
if ((counter >= comingOutofNutralToReverse ) && (counter <= forceToNutralLowSpot))//forceToNutralHighSpot
programSpot = 5;
counter = 0;
Serial.println(" 5");
//while (ForwardReverseStepper.currentPosition() != 0){
//ForwardReverseStepper.moveTo(0);
//ForwardReverseStepper.run();
///digitalWrite(stepperEnable, LOW);// low enables
//if ((counter >= forceToNutralHighSpot ) && (counter <= comingOutofNutralTowardsForward))
programSpot = 6;
//currentStepperPosision = 0;
//counter = 0;
Serial.println(" 6");
startCheck;
Wow! Do you ever stop to take a breath?
Sorry but I had to spread it out to make it easily read.
Try point form when you write intros like this.
Can we please have a circuit diagram?
An image of a hand drawn schematic will be fine, include ALL power supplies, component names and pin labels.
Thanks.. Tom.. :grinning: :+1: :coffee: :australia:
must be startCheck();
    programSpot = 6;
are you sure condition check should be commented out?
void startCheck() {
  while (digitalRead (startIndicator) == 0) {
strange construct
:face_with_monocle: good ketch ty
ok fixed that thanks
ok fixed that TY
Well you mean in between Ideas of course
That part isn't working yet `````void startCheck() {
while (digitalRead (startIndicator) ==1) {
if ((digitalRead (startIndicator) == 0) ) {
I had that backwards I think.
if i know you project better i may have improvements.
You have such comments like this
stepper-motors should always be driven in a way that you never loose steps except you have a very unusual mechanical problem that is causing loosing steps !
So if you loose steps you should use a stronger stepper-motor or a gear to increase the torque on the cost of slower speed.
Trying to write code that adds some steps will end up in your code does no longer "know" in what position your whole thing is.
You should either have additional position-sensors that switch their state if your linear moving part of your mechanic is in the right position or using a motor with position-feedback through an encoder or to use a servo-motor.
Servomotors manage to reach the given position inside their own controller.
About loosing encoder-pulses. There are encoder-libraries that are interrupt-driven. These libraries don't loose steps. Disadvantage you need interrupt-cabable IO-pins.
What Microcontroller are you using. An Arduino-Uno has only two interrupt-capable IO-pins.
best regards Stefan
No it’s not the stepper that loosing steps . The steps are getting lost at the input end of things
what do you mean with "at the input end of things" ??
what input ?
what "thing"??
Can’t you just use conventional cable controls as do boats with steering wheels at the front and outboards at the back .
A boat is a very difficult environment to enact your own β€œ fly by wire β€œβ€˜ - water proofing , vibration, fail safes , power supply , reliable connections .
What if it fails ?
if photos or pictures are not allowed, maybe you can show a freehand drawing of what your system looks like?
Hi, @kb9vjq
Some images of your project would also help?
Can you please post link to specs/data of your stepper driver?
Can you please post link to specs/data of your stepper motor?
