bonehead about servo sweep  running ard 0017
Am trying to learn programming. Have seen what others are doing and came up with this adaptation to move a bot and avoid objects. I would like to sweep the head or "scan", and have come close but no cigar. This code sweeps the head but very fast one way and slow the other; so only steps by 1, in one direction. It only reads the sensor at the end of the sweep. If I remove the scan code the bot works fine with the sensor looking ahead only and sees walls, etc. What am I not seeing? Thanks much, this is a great site.
    #include <Servo.h>
Servo left;
Servo right;
Servo head;
int pos = 0;
int headPos = 0;
int value = 0;
int treshold = 150;
int sensor = 0;
  Serial.begin  (9600);
  right.attach(10);
  left.attach(9);
  head.attach(6);
void ReadSensor () {
  for(headPos = 0; headPos <180; headPos += 1)
    head.write(pos);
    delay(10);
  for(headPos = 180; headPos >= 1; headPos-=1)
    head.write(headPos);
    delay(10);
  value = analogRead(0);
  Serial.println(value);
  if (value > treshold) {
    turn();
    move();
void turn () {
  left.write(145);
  right.write(145);
void move () {
  left.write(135);
  right.write(45);
  ReadSensor();
    head.write(pos);
    delay(10);
    delay(10);
I'd say that you're probably missing some "}" braces in there.
Or they're misplaced, which is more likely if this code is compiling
  for(headPos = 0; headPos <180; headPos += 1)  {
        head.write(pos);
        delay(10);
       // You may want to do stuff here
  for(headPos = 180; headPos >= 1; headPos-=1) {
      delay(10);
         turn();
         move();
Thanks AWOL, think you are right. I have played with moving the braces around and every iteration that will compile (quite a few) also acts differently. Guess I have to find the right combo. Thanks again.
