Voici l'erreur :
In file included from C:\Users\user\Documents\Arduino\sketch_feb18a\sketch_feb18a.ino:2:0:
C:\Users\user\Documents\Arduino\libraries\USBKeyboard-master/USBKeyboard.h: In member function 'void USBKeyboard::sendKeyStroke(byte, byte)':
C:\Users\user\Documents\Arduino\libraries\USBKeyboard-master/USBKeyboard.h:32:22: error: call of overloaded 'write(int, int)' is ambiguous
Serial.write(0, 1); // Reserved
C:\Users\user\Documents\Arduino\libraries\USBKeyboard-master/USBKeyboard.h:32:22: note: candidates are:
In file included from E:\Arduino\hardware\arduino\avr\cores\arduino/Stream.h:26:0,
from E:\Arduino\hardware\arduino\avr\cores\arduino/HardwareSerial.h:29,
from E:\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:232,
from sketch\sketch_feb18a.ino.cpp:1:
E:\Arduino\hardware\arduino\avr\cores\arduino/Print.h:57:12: note: size_t Print::write(const char*, size_t)
size_t write(const char *buffer, size_t size) {
E:\Arduino\hardware\arduino\avr\cores\arduino/Print.h:56:20: note: virtual size_t Print::write(const uint8_t*, size_t)
virtual size_t write(const uint8_t *buffer, size_t size);
C:\Users\user\Documents\Arduino\libraries\USBKeyboard-master/USBKeyboard.h:34:22: error: call of overloaded 'write(int, int)' is ambiguous
Serial.write(0, 1); // Keycode 2
C:\Users\user\Documents\Arduino\libraries\USBKeyboard-master/USBKeyboard.h:34:22: note: candidates are:
C:\Users\user\Documents\Arduino\libraries\USBKeyboard-master/USBKeyboard.h:35:22: error: call of overloaded 'write(int, int)' is ambiguous
Serial.write(0, 1); // Keycode 3
C:\Users\user\Documents\Arduino\libraries\USBKeyboard-master/USBKeyboard.h:35:22: note: candidates are:
C:\Users\user\Documents\Arduino\libraries\USBKeyboard-master/USBKeyboard.h:36:22: error: call of overloaded 'write(int, int)' is ambiguous
Serial.write(0, 1); // Keycode 4
C:\Users\user\Documents\Arduino\libraries\USBKeyboard-master/USBKeyboard.h:36:22: note: candidates are:
C:\Users\user\Documents\Arduino\libraries\USBKeyboard-master/USBKeyboard.h:37:22: error: call of overloaded 'write(int, int)' is ambiguous
Serial.write(0, 1); // Keycode 5
C:\Users\user\Documents\Arduino\libraries\USBKeyboard-master/USBKeyboard.h:37:22: note: candidates are:
C:\Users\user\Documents\Arduino\libraries\USBKeyboard-master/USBKeyboard.h:38:22: error: call of overloaded 'write(int, int)' is ambiguous
Serial.write(0, 1); // Keycode 6
C:\Users\user\Documents\Arduino\libraries\USBKeyboard-master/USBKeyboard.h:38:22: note: candidates are:
C:\Users\user\Documents\Arduino\sketch_feb18a\sketch_feb18a.ino: In function 'void setup()':
C:\Users\user\Documents\Arduino\sketch_feb18a\sketch_feb18a.ino:5:25: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
Keyboard.print("Coucou");
exit status 1
Erreur de compilation pour la carte Arduino/Genuino Uno
