Hello there, im trying to figure out how to check all three operand at the same time given that these is a obstacle avoiding robot that have all 3 ultrasonic sensor at all three direction. and i wanted to include the scenario where all three statement are true which is "(Mdistance < maxFrontDistance)" ,"(Ldistance < maxLeftDistance)" and "(Rdistance < maxRightDistance) " so that i can execute the task such as moveBackward(). i have look it up and someone suggested using the boolean expression of "&&" can anyone help me , bellow is my current coding.
SpeedControl = analogRead(A0);
MotorSpeed = map(SpeedControl, 0, 1023, 0, 255);
checkFrontDistance();
if (Mdistance < maxFrontDistance) {
checkLeftDistance();
delay(20);
checkRightDistance();
delay(20);
if (Ldistance < Rdistance)
turnRight();
else if (Ldistance> Rdistance) {
turnLeft();
else{
moveForward();
if (Ldistance < maxLeftDistance) {
delay(20);
delay(20);
if (Ldistance > Rdistance)
moveForward();
else if (Ldistance < Rdistance) {
turnRight();
if (Rdistance < maxRightDistance) {
delay(20);
delay(20);
if (Rdistance >Ldistance)
moveForward();
else if (Rdistance < Ldistance) {
turnLeft();
if (Mdistance < maxFrontDistance && Ldistance < maxLeftDistance && Rdistance < maxRightDistance)
//execute this code if all 3 conditions are true
Will it contradict with the my existing coding, because i had run a stimulation and it does not execute the coding
Williamsccz:
That depends on where you put the test and the code that it executes if true
Please post the sketch with the new code in it
Williamsccz:
if (Mdistance >= maxFrontDistance)
// No obstacle in front
moveForward();
// Obstacle in front, check the sides
if (Ldistance < maxLeftDistance && Rdistance < maxRightDistance)
// Obstacles in front AND both sides
moveBackward();
// Obstacle in front but not on both sides
// Turn toward the side with the further obstacle.
turnRight();
turnLeft();
Works for me thank you so much
johnwasser:
moveForward();
moveBackward();
turnRight();
turnLeft();
Thank you to you too good sir!
UKHeliBob:
