Boolean Function
i Arduino Community
I Hope somebody of you can help me with my problem:
Basically i try to manage that the Arduino is waiting for an ACK Message at the Serial Port before i send further Instructions to the Slave.
I'm using an Arduino Mega2560 as a Master of an EPOS2 50/5 by Maxonmotor. The communication goes over the Serial1 Channel.
I have tryed to declare the Waiting for the Acknowledge as a Function of the Datatype Boolean who turns false at receiving the Ack... But the Compiler is Reporting following Failure:
"function definition does not declare parameters"
And when i declare a boolean Variable as Argument of the Function its reporting:
"WaitforAck was not declared in this scope".
I have here a snippet of my Sketch:
byte ack, failack, OpCode, RXmot1[1];
Serial1.begin(9600);
OpCode= 0x11;
ack = 0x4F;
failack =0x46;
Serial1.write(OpCode);
while (WaitforAck)
Serial1.write(Commandword);
while (WaitforAck)
boolean WaitforAck
return=true;
Serial1.readBytes(RXmot1[0], 1);
if (RXmot1 == ack)
return false;
Serial.println("Received ACK");
else if (RXmot1 == failack)
return true;
Serial.println("Received FailAck");
}else
return true;
Serial.println("Serial Timed Out");
Where is my fault? Or is there an much easier Way to wait for an specific incoming Byte at the SerialPort?
Many Thanks
Vortex86
A one element array just screams clueless.
boolean WaitforAck
All function declarations need parentheses around the argument list, EVEN IF THE LIST IS EMPTY (like it is for loop()).
return=true;
return is a keyword. You can NOT use it as a variable name. Variables must be typed.
if (RXmot1 == ack)
return false;
It's pointless to put anything after the return statement. The return statement terminates the function. Obviously, nothing after that will be executed.
several mistakes,
I stripped it to something working fixing the errors, should get you going
byte ack, failack, OpCode;
char RXmot1;
  OpCode= 0x11;
  ack = 0x4F;
  failack = 0x46;
  Serial.write(OpCode);
  while (WaitforAck())
boolean WaitforAck()
  RXmot1 = Serial.read();
  if (RXmot1 == ack)
    return false;
    return true;
    return true;
Thanks a lot! I will try it as soon i have access to my Board :sunglasses: !
This means that the Program is entering the While loop and waits there until the WaitforAck turns false...
So how di i ensure that the boolean expression WaitforAck is true at the beginning because the While Loop is checking the expression before execution. In a bad case there is no execution...
Cheers
Vortex
in C such a waiting loop is often written as
while (WaitforAck());
