#include <Servo.h>
//FijiBot
//Light Seeking Robot made out of a 1.5 liter Fiji Water Bottle
// by Mike Soniat (msoniat@gmail.com)
// 8/7/2012 Posted to github
//debug
bool showReadings = true;
bool showDirections = true;
bool seekLight = true;
bool avoidStuff = true;
//assign servos
Servo rightServo; //Digital Pin 7
Servo leftServo; //Digital Pin 12
Servo pingServo; //Digital Pin 11
Servo turnServo; //Digital Pin 10
//Ping
const int pingPin = 9;
const long minClearanceInches = 36;
const long minTurnClearance = 12;
bool clearPath = true;
bool rightClear = true;
bool leftClear = true;
bool tooCloseToTurn = false;
int backUpCount = 0;
//assign analog pins to photoresistors
const int frontSensorPin = 2;
const int rightSensorPin = 3;
const int leftSensorPin = 4;
const int topSensorPin = 5;
//assign digital pins
const int greenLED = 5;
const int redLED = 6;
//rear wheels
const int rotateLeft = 150;
const int rotateRight = 0;
const int fullStop = 90;
//light readings
int readings[4] = {0,0,0,0};
int highestReading = 0;
//looking
const int headRight = 0;
const int headLeft = 160;
const int headForward = 80;
//turning
const int turnRight = 75;
const int turnLeft = 102;
const int goStraight = 90;
void setup(void){
pinMode(redLED, OUTPUT);
pinMode(greenLED, OUTPUT);
rightServo.attach(7);
rightServo.write(fullStop); // initialize right servo
leftServo.attach(12);
leftServo.write(fullStop); //initialize left servo
pingServo.attach(11);
pingServo.write(80); // initialize Ping servo
turnServo.attach(10);
turnServo.write(90); // initialize turn servo
//while(1) {}
//delay on start; blink leds five times
for (int i = 0; i < 5; i++)
digitalWrite(greenLED, HIGH);
digitalWrite(redLED, HIGH);
digitalWrite(greenLED, LOW);
digitalWrite(redLED, LOW);
void loop(void){
Serial.println("Top of Loop");
if (seekLight == true)
//read photoresistors
readings[0] = analogRead(frontSensorPin);
readings[1] = analogRead(rightSensorPin);
readings[2] = analogRead(leftSensorPin);
readings[3] = analogRead(topSensorPin);
highestReading = 0;
//display readings front, right, left, top and get highest
for (int i = 0; i < 4; i++)
if (showReadings == true) {Serial.print(readings[i]);}
if (readings[i] > readings[highestReading])
highestReading = i;
if (i < 3)
if (showReadings == true) {Serial.print(", ");}
if (showReadings == true) {Serial.println("");}
highestReading = 0;
if (highestReading != 3)
//check forward path
lookForward();
clearPath = pingBlocked() > minClearanceInches;
if (tooCloseToTurn)
highestReading = 4; //backup
else if (!clearPath)
if (readings[1] > readings[2] && lookRight() > minTurnClearance)
highestReading = 1; //turn right
else if (lookLeft() > minTurnClearance)
highestReading = 2; //turn left
lookForward();
//move toward light or unobstructed path
switch ( highestReading )
case 0 : //front
if (showDirections == true) {Serial.println("Go Forward");}
setMotors(rotateLeft, rotateRight, goStraight);
case 1 : //right
if (lookRight() > minTurnClearance)
if (showDirections == true) {Serial.println("Turn Right");}
backUpCount = 0;
lookForward();
setMotors(rotateLeft, rotateRight, turnRight);
lookForward();
case 2 : //left
if (showDirections == true) {Serial.println("Turn Left");}
backUpCount = 0;
lookForward();
setMotors(rotateLeft, rotateRight, turnLeft);
lookForward();
case 3 : //top
if (showDirections == true) {Serial.println("Stop");} //highest light level above; stop and bask
setMotors(fullStop, fullStop, goStraight);
case 4 : //backup
backUpCount++;
if (backUpCount < 2)
if (showDirections == true) {Serial.println("Backup");}
setMotors(rotateRight, rotateLeft, goStraight);
//if already backed up twice, try short right turn
backUpCount = 0;
void setMotors(int left, int right, int turnPos)
if (showDirections == true) {Serial.println("Clear Path");}
turnServo.write(turnPos);
leftServo.write(left);
rightServo.write(right);
delay(20);
long pingBlocked()
long duration, distance;
//initialize Ping with LOW then HIGH
pinMode(pingPin, OUTPUT);
digitalWrite(pingPin, LOW);
delayMicroseconds(2);
digitalWrite(pingPin, HIGH);
delayMicroseconds(5);
//read Ping
pinMode(pingPin, INPUT);
duration = pulseIn(pingPin, HIGH);
//convert microseconds to distance in inches
distance = microsecondsToInches(duration);
Serial.print(duration);
Serial.print(", ");
Serial.println(distance);
//fix for no reading (distance = 0)
if (distance == 0)
distance = minClearanceInches;
//check for turn clearance
tooCloseToTurn = distance < minTurnClearance;
//compare to minClearanceInches
return distance;
long microsecondsToInches(long microseconds)
// The speed of sound is 13512 inches per second, which is 74 microseconds/in
// Sound travels out and back to the Ping, so find half the distance recorded
return microseconds / 74 / 2;
long lookRight()
//turn Ping to right
if (showDirections == true) {Serial.println("Look Right");}
pingServo.write(headRight);
return pingBlocked();
long lookLeft()
//turn Ping to left
if (showDirections == true) {Serial.println("Look Left");}
pingServo.write(headLeft);
void lookForward()
//turn Ping to front
if (showDirections == true) {Serial.println("Look Forward");}
pingServo.write(headForward);
What is the significance of these codes in this program
