This is my code. I’m trying to get my LCD screen to connect to my Arduino, manually input a word, and get another word as an output. Is there a way to do this?
// include the library code: #include <LiquidCrystal.h>
// initialize the library with the numbers of the interface pins
LiquidCrystal lcd(12, 11, 5, 4, 3, 2);
// set up the LCD’s number of columns and rows:
lcd.begin(16, 2);
// Print a message to the LCD.
lcd.print(“Type a genre.”);
lcd.begin(16, 2);
// initialize the serial communications:
// when characters arrive over the serial port…
if (Serial.available()) {
// wait a bit for the entire message to arrive
delay(100);
// clear the screen
lcd.clear();
// read all the available characters
while (Serial.available() > 0) {
// display each character to the LCD
lcd.write(Serial.read());
if (Serial.read == “pop”) {
lcd.print(“Shut Up and Dance by Walk the Moon”);
else if (Serial.read == “edm”) {
lcd.print(“Where are U Now by Jack U, Skrillex, Diplo, JB”);
else if (Serial.read == “country”) {
lcd.print (“Sangria by Blake Shelton”);
else if (Serial.read == “r&b”) {
lcd.print (“All of Me by John Legend”);
else if (Serial.read == “rock”) {
lcd.print (“Centuries by Fall Out Boy”);
else if (Serial.read == “alternative”) {
lcd.print (“Dog Days by Florence and the Machine”);
Serial.read() reads one character so this will never be true. In any case you have already emptied the serial buffer and displayed the characters. If you want to compare what you received then you need to save it until it is complete (how will you know ?) and then do the comparison.
Serial.read() simply reads a byte at a time. It doesn't wait or store the data. Try something like:
// inside loop()
char message[20]; // Probably longer than you need
int charsRead;
charsRead = Serial.readBytesUntil('\n', message, sizeof(message) - 1); // Save room for null
message[charsRead] = '\0'; // Now it's a string
if (strcmp(message, "pop") == 0) {
lcd.print("Shut Up and Dance by Walk the Moon");
if (strcmp(message, "edm") == 0) {
lcd.print("Where are U Now by Jack U, Skrillex, Diplo, JB");
// and so on...
The readBytesUntil() method reads the Serial object until either the Enter key was pressed or 19 characters are read, whichever comes first. When using character arrays for string, use strcmp() to compare strings.
EDIT: Also read Nick Gammon's two posts at the top of the Forum for guidelines on how to properly post code here using code tags.
// set up the LCD's number of columns and rows:
lcd.begin(16, 2);
lcd.print("Type a genre.");
lcd.begin(16, 2);
// when characters arrive over the serial port...
delay(100);
// clear the screen
lcd.clear();
// inside loop()
int charsRead;
lcd.print("Shut Up and Dance");
lcd.print("Where are U Now");
else {
if (strcmp(message, "alternative") == 0) {
lcd.print("Dog Days");
else {
if (strcmp(message, "r&b") == 0) {
lcd.print("All of Me");
else {
if (strcmp(message, "rock") == 0) {
lcd.print("Centutries");
else {
if (strcmp(message, "country") == 0) {
lcd.print("Sangria");
Since I don’t have an LCD display handy, I just duplicated the output for the Serial object. While this code works, you’ll want to change it after you get comfortable with arrays.
lcd.begin(16, 2);
lcd.begin(16, 2);
int charsRead;
Serial.println("Shut Up and Dance");
} else
Serial.println("Where are U Now");
} else
Serial.println("Dog Days");
} else
Serial.println("All of Me");
} else
Serial.println("Centutries");
} else
Serial.println("Sangria");
