I just had a sketch blow up when using a newer version of the compiler. I assume I was, once again, the victim of bad code that worked for no particular reason...
I was repeatedly loading a two place array with incoming characters. Those two characters were then transformed into a numerical hex value. For the index of that two place array, I was using a boolean called byteIndex.
I was relying on byteIndex++; to rollover to 0 if it was 1, using the same logic that adding 1 to a uint8_t of 255 = 0.
An index in general by meaning is a number not a truth statement
it is an arbitrary programming language convention to have false at 0 and true at 1. Good compilers and pre-processors will bark at you with type mismatch if you try to access an array with a Boolean as an index
if you want to optimize memory usage because you know it's less than 255 you can use a byte and for larger values use unsigned int or unsigned long depending on your requirements
An example is not a proof of general case. As a counter example, CAML would bark at you if you were trying to do math operations with booleans.
Yes C++ fully defines Boolean promotion into int as 0 and 1 (bool values behave as integral types and participate in integral promotions). I maintain this is arbitrary decision taken by the designers, they could have chosen something different.
Often one associates true to correct and false to error. Now - Take C functions or UNIX/shell commands that return zero when all was correct, you could say this feels weird because if all went well the function should give you a positive truth answer -but because you want to be able to return different error codes, then the convention has been 0 is all ok and anything else is error.
As I said it is language dependent. While it is safe to make such assumption in C++ because it is properly documented (and in many languages) it is still a bad conceptual shortcut (that we often take)
Fair enough on the exact terminology of arbitrary. There is some rationale behind it I'm sure - but how much of it is inertia/backward compatibility with c which had not conceptual type for Boolean. If you know I would be interested in knowing why we have this originally? Switch/transistor closed versus open?
Is it OK to disagree with a 5 star general here?
His last question was
Carrying the thought a bit farther... would it be considered poor style or technique to use a boolean type for a value, such as an index?
I took that as a general question on programming, not a C++ related question - hence my comment.
To go back to the very first question and in C++
I do believe the original code should indeed alternate between true and false (and personally see that as bad intellectual practice in general case)
A prvalue of integral, floating-point, unscoped enumeration, pointer, and pointer-to-member types can be converted to a prvalue of type bool. The value zero (for integral, floating-point, and unscoped enumeration) and the null pointer and the null pointer-to-member values become false. All other values become true.
Sorry yes you are 100% right, I don't know what I was thinking - as my quote stated Indeed the C++ definition states that any non zero will go back to true so 1 when you increment.
J-M-L:
Yeah, you'd sort of expect that it would roll over like, for example, 'byte' in the following code, but not so unfortunately.
