Boolean operator
I am copying a code that uses a Boolean operator which I cannot find on my key board. The Boolean Operator looks like two straight vertical dashes and is being used in a" if " control operator.
Mine is above the enter key.
You can also say "or", as in
if (a==b or c==d)
the same as
if (a==b || c==d)
Similarly, "and" for &&.
It took them years. Sigh.
Edit - corrected errors
Yes, but when 'or' became a keyword it can't be a variable name which will break old code.
BTW, you have to type two, the key produces one |, so you need to hit it twice. Also, on my keyboard it is shown with a gap in the middle for some reason, so it looks like a malformed colon.
And please don't use
a=b
which will assign the value of b to a - but is perfectly legal to use as is.
Instead, use
a==b
KeithRB:
Yes, but when ‘or’ became a keyword it can’t be a variable name which will break old code.
Boo hoo. :slight_smile:
That's the "pipe" symbol, on US keyboards its [SHIFT] + [BACKSLASH]. In unix shells its used to "pipe" the output of one command into the input of another, as in:
dmesg | less
KeithRB: ... so it looks like a malformed colon.
yikes... you have a proctologist's eye.
KeithRB: Yes, but when 'or' became a keyword it can't be a variable name which will break old code.
They made 'or' a keyword‽ What is this kindergarten-grade madness‽
On my keyboard (azerty) it's AltGr + 6
aarg: You can also say "or", as in
if (a=b or c=d);
the same as
if (a=b || c=d);
You mean:
if (a==b or c==d)
No semicolon, and two of ==.
Please correct your earlier post.
