Boolean
Hey guys,
Can you use Boolean's with the Arduino? They compile fine but don't seem to be working for me:
In my code I Initialise my boolean like so:
boolean tagged = false;
I then to be really sure set it to false just before I enter a loop depending on it.
tagged=false;
while (tagged = false)
//do stuff
When I try it like this the while loop is skipped over, When I change the while condition to true it enters the while loop. However even if in the while loop I put tagged=false; it still won't change and the loop continues forever.
Any ideas?
Boab,
That should be:
while (tagged == false)
  // do something
The problem was that you were using '=' instead of '=='. Comparison is done with the '==' operator.
You could also change your 'while' to be more concise:while (!tagged)Regards,
-Mike
Thanks Mike, That worked Thanks for the help
Just so its clear in my mind
if I put
tagged = !tagged;
does that set tagged to false each time or does it change it to whatever it wasn't before?
If it changes it to what it wasn't before how do I set it specificly to true or false regardless of what it was previous
tagged == false; doesn't seem to work for me
tagged = !tagged; will set tagged to true if it was false, or to true if it was false.
tagged == false; is a comparison operation. tagged = false; is an assignment operation.
