Say i have a boolean fuction such as this one:
boolean joyFL(){
if (joyy > 130 && joyx < 125){
return true;
else{
return false;
And i want to check if it is true in another part of my code...
is this
if (joyFL() == true){
leftForward();
the same as this
if (joyFL()){
leftForward();
Thank you!
LarryD
2
And when you tried it what happened
holmes4
3
How can you have a value greater than 130 AND less than 125?
Mark
KenF
4
In answer to your actual question. Yes.
I will try it i just didnt with that example because i would have to hook up my entire robot to try it.
And for holmes, if you check it properly its not the same integer one is 'joyy' and the other 'joyx'.
And thank you Ken !
KenF
6
But you could simplify it to
boolean joyFL()
return (joyy > 130 && joyx < 125);
holmes4:
Mark
Quite easily, if one is joyY and the other is joyX
OP org. question answer: Yes.
But you could have easily created a small program to test the logic without using the robot or the rest of the code for it such as
byte joyx = 120;
byte joyy = 140;
Serial.println("true");
if (joyFL()){
void loop() {}
boolean joyFL()
return true;
return false;
