I have a 5v board with FM radio and am planning to use 3.7v LiPo or 2x 3.7v LiPo. What woud be the best way to power it, 2 x 3.7 in series plus stepdown or linear converter (because dont want any RF interference) or 1x or 2x3.7 in parallel and booster? Maybe there are other options? The max power is is to drive 2x 50ohm headphones. Thanks.
PS. idealy i'd like to be able to charge it conviniently too
3x lipo in series with a simple 7805. Using just two probably will teeter on the brink of the 7805's lower input limit. I'm not sure if a low dropout regulator can be used here...
If its working as per expectation then go ahead with it. If its hi-end (audiophool) performance you're looking for then any kind of switching supply has to have very tight noise control else it can get into the audio.
All said, linear supplies are inherently low noise and simpler to construct out of discrete parts, only downside is that linear supplies are bulky due to the power transformer which is the heaviest and largest part.
