Bootloader burn failed + 'L' led blinking (solved)
Hi everyone.
I’ve got an arduino duemilanove, and because I was too “curious” I break the bootloader.
I tried to fix it with the burn bootloader tool, but I get this error
avrdude: stk500_getsync(): not in sync: resp=0x00
avrdude: stk500_disable(): protocol error, expect=0x14, resp=0x51
After that I tried to burn the bootloader with an ISP programmer, uploading the ATmegaBOOT_168_atmega328.hex file, and it seemed to work, but when I try to upload a sketch I get the same error.
Furthermore I saw that the ‘L’ led from the board is blinking continuously, and I don’t know what does it mean… :-?
I searched all the info I could, but I couldn’t fix it :’(
Can someone help me??
Furthermore I saw that the 'L' led from the board is blinking continuously, and I don't know what does it mean..
It is the default sketch meaning the arduino is working.
You will you can't burn a boot loader without a programmer. The arduino IDE is looking for one and doesn't see one and so you get the error.
Are you sure this is the right file?
The name looks odd having both 168 and 328 in the title.
Are you using the 328 chip?
Sorry I forget:
I've got XP Pro
Arduino Duemilanove
Arduino Alpha 0021
Yes, I have a 328P chip
I picked the file from:
..arduino-0021\hardware\arduino\bootloaders\atmega
Is it the right file?
I uninstalled all the COM ports of my computer and "reinstall" all of them.
And my board is running one more time!! ;D ;D
