Bootloader for Nano
Hello all I got an Nano 3.0 clone, but it is not having a bootloader installed.
When I look into the hardware/bootloaders folder, I see there are many different to choose from.
If someone could tell me which hex file to install, I think I can manage to install it myself.
Best regards Per-Jarle
Duemilanove 16MHz [assuming IDE Arduino-0022]
RP is correct, the default Nano bootloader is the one from the Duemilanove.
I reflashed my Nano with OptiBoot (the bootloader used on the Uno) and have had no problems. I've now got OptiBoot running on all my boards & standalone chips; now I can leave the board at "Uno" and not have to switch every time I move between projects.
I do the same - all my '328P projects are bootloaded as Unos.
I understand how to put Optiboot on a 328 chip. I use the Uno board as explained on the site. How do you burn a new bootloader to a chip on a surface mount board such as Nano?
The exact same way. D10 on the Arduino running the bootloader upload script to the reset pin on the Nano, D11 - 13 from the uploader to pins D11 - 13 on the Nano, ground to ground, and 5v to 5v.
[quote author=joe mcd link=topic=141923.msg1066569#msg1066569 date=1357858110] How do you burn a new bootloader to a chip on a surface mount board such as Nano? [/quote]
I use the ICSP via USBtinyISP. (I've seen available a "Nano" that shipped/s without the ICSP header - unpopulated pads.)
