Has anybody come across any issues downloading the bootloader from the Arduino Uno running on a 16MHz Clock to a slave Atmega 328 chip running on a 20MHz clock, will this affect the transmission speeds between devices? or do they both have to run on the same clock frequency. Anyone tried this?
(deleted)
The difference in clock speed is not important. The programmer just has to use a data rate of 1/4 the target clock speed for clocks less than 12 MHz and 1/6th the clock speed for anything else. When the target is running at 20 MHz the clock pulses have to be LOW for at least 3 cycles and HIGH for at least 3 cycles. That gives a data rate up to 3.333 MHz. Any rate slower than that will work and since uploading to a factory default chip running at 1 MHz works, it is clear that the data rate is WAY under 3.333 MHz.
