Bootloader Improvements for Watchdog Timers
Much more robust Arduino based devices could be built if the watchdog timer were addressed in the bootloader. Specifically:
  • Have the bootloader run the user sketch even if the most recent reset was caused by a watchdog timeout.
  • Insert periodic calls to the GCC wdt_reset() function so the WDT wouldn't timeout while the bootloader code was executing.
I was recently asking questions about the WDT and Arduino in the following forum thread:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1260378037
Tim
Hi Tim,
I agree with you, the WDT handling should be enabled by default in the bootloader.
If you want to enable this yourself, please look here:
http://www.arduino.cc/cgi-bin/yabb2/YaBB.pl?num=1255016475/1
You can see, its less a technical problem, but a compatibility and support problem because Arduino users have to understand, that they need a bootloader version >= Vx.y to use a specific feature.
Michael
